Originally Posted by SandyGames There are the same. (DVI-D) |
Hate to say it but I'm not sure what else you can do without switching cards or upgrading to a digital display. DVI-D ports just don't have the extra pins that DVI-I ports use to make DVI to VGA adapters work.
I can confirm that Galaxy's GTX 650 GC has the DVI-I you need. In fact, we include the VGA adapter in the box and use shielded DVI-I ports on our cards which make the analog signal a lot cleaner. Not sure if swapping cards is an option for you at this stage, but I believe a new display would be your only other choice unfortunately.
