-   -   7970 + 6950= gaming bliss? (http://www.hardwarecanucks.com/forum/video-cards/58297-7970-6950-gaming-bliss.html)
HoserEh December 4, 2012 05:13 PM
I recently did a system upgrade and I have my old 6950 kickin around, I could sell it or pop it into my wifes web surfin machine.But i was wondering if i could CF the 7970 with 6950 (I assume no) and if no could use it for ohysics offload and the such.
great_big_abyss December 4, 2012 05:18 PM
Short, easy answer: No.
Sell it and recoup some of your money. You could get $175 - $200 for it...
Bond007 December 4, 2012 05:50 PM
As mentioned above.
Arinoth December 4, 2012 06:24 PM
Nope, different architectures and only physics benefits you'd get is if that card was an nvidia one
tethlah December 5, 2012 07:16 AM
Think of it this way, pretty much anything that runs in tandem with another part in a computer will throttle itself to match the lower performing part in order to keep from damage or the creation of a black hole in your computer (sounds like it could be fun, but trust me, black holes, while fun to play with, do not belong anywhere near your GPU)
Master_Shake_ December 5, 2012 07:21 AM
im gonna try that on one of my hydra boards and see if i can "crossfire" a 7970 with a 6970.
great_big_abyss December 5, 2012 07:35 AM
It just won't work. The way the two different architectures process data and render pixels is completely different. The 7XXX series was essentially a complete re-invention of graphics technology.
But, if you really want to put two cards on the same board and install a crossfire connector, good luck. I'm pretty sure you won't blow anything up, but have fun getting to play together at all.
Bloodystumps December 5, 2012 08:42 AM
if he means hydra as in Hydra lucid it shouldn't be to much trouble and he may benefit from it ..
I messed around with mine when I first got it but couldn't be bothered any more because all my gear is under water and I didn't have the time to re plumber everything ever time and I ended up stuffing my GTX280 in my HTPC
great_big_abyss December 5, 2012 08:44 AM
Cool. Didn't know that was a thing. Sounds like fun! This is my new thing learned for the day.
Master_Shake_ December 5, 2012 09:08 AM
Pure Black P67 Hydra (PB-CI7S42P67)
this board
