Old December 3, 2012, 12:23 PM
r0k0's Avatar
Default HDMI Question
Hey guys i know it might be stupid to ask but im asking it
my 2 ATi cards have HDMI Built in, my Acer 23" screen has HDMI on it
is there a image difference from playing with HDMI cable and DVI-D ?
its currently plugged DVI but never tried HDMI to see if their was a difference
Thanks
Main Rig
Intel Core i5 2500K - 5.0
Asus Maximus Gene-Z / Gene 3
4x 4GB Corsair Vengence DDR3-1600
AMD Radeon HD 6990 4GB 880 / 1300
Crosair 600T White / Enermax Revolution 920W
A-DATA 120GB SATA3 SSD / Seagates 1TB Spare SATA3
Canadian Eh ?
Old December 3, 2012, 12:30 PM
Something I found that would be helpful for you: HDMI Vs. DVI-D Cable | eHow.com
The short of it is that HDMI is derived from DVI-D, but only HDMI supports audio out of the two. Otherwise, pretty much the same beside a couple minor differences.
Old December 3, 2012, 12:42 PM
r0k0's Avatar
i dont need that, both my card and screen has HDMI and DVI, im just asking if theirs a benefit from HDMI to DVI ? like if the image is nicer when plugged HDMI instead of DVI
Main Rig
Canadian Eh ?
Old December 3, 2012, 01:41 PM
Read the bolded part if you don't want to read the article.
So in shorter, you're fine with DVI-D.
Edit: There is one thing that's not in the article, I'm pretty sure that if you want to use 3D you need to use DIV-D Dual Link because of bandwidth issues.
Old December 3, 2012, 02:14 PM
Same quality. Digital is digital. Dvi, however, is capable of higher resolutions at its limit(I believe)
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old December 3, 2012, 04:53 PM
JD JD is offline
HDMI (typically) caps you at 1080p. DVI-D does not. And as mentioned, you get audio with HDMI too.
Old December 3, 2012, 05:03 PM
r0k0's Avatar
alright thanks everyone
tethlah sorry i didn't read properly i just overlook the hmdi to dvi connector lol
Main Rig
Canadian Eh ?
Old December 3, 2012, 07:39 PM
Galcobar's Avatar
HDMI's maximum resolution depends on the revision of the source, the cable, and the receiver; HDMI 1.4b maxes out at 1920x1080 at 120 FPS, while higher resolutions require lower frame rates.
Old December 4, 2012, 06:09 AM
Can it run 2 side by side 60hz transmissions for 3D though? That's the part I always get mixed up, I'm pretty sure it can't.
Yet another HDMI connection question Ogren Display Units 10 February 1, 2012 05:18 PM
LAPTOP HDMI TO LCD TV HDMI NOT WORKING appplejack Display Units 14 January 25, 2012 06:50 PM
DVI-HDMI cable question on HD 4890 Darthzin Video Cards 8 January 11, 2012 12:42 PM
HDMI Cable Question Supergrover HTPC Systems & Software 11 June 30, 2008 07:53 PM
