<~----> A question about switching card brands. - Hardware Canucks
Old November 26, 2012, 02:57 AM
Default A question about switching card brands.
So, I recently purchased a GTX 660 Ti and I currently have a HD 6950. I was wondering what I need to do to switch them. Do I need to uninstall AMD then install nvidia? Any help would be appreciated. :)
Old November 26, 2012, 01:19 PM
Anyone know? My card is coming tomorrow.
Old November 26, 2012, 01:20 PM
Pretty much!
Old November 26, 2012, 01:24 PM
Bloodystumps's Avatar
clean the old driver with Phyxion and you should be fine ....
Old November 26, 2012, 01:52 PM
19.99 Am i missing something?
Old November 26, 2012, 02:06 PM
He's saying to get rid of the old drivers and software, then AFTER that install your new card and install/configure what you need to with that. Honestly you can run the two side by side but it's a pain, for me it's easier to remove the old card, boot, remove everything, install new card, install everything.
Old November 26, 2012, 02:21 PM
Okay thanks guys! Card's comming tomorrow and I'll let you know if I get it up and running!
Old November 26, 2012, 04:50 PM
mybad I didn't notice they are charging for it now . if you are able try doing this . remove the card then reboot then uninstall the drivers shut down the PC pop new GFX card in and load up the new drivers . Might want to search your local drive for AMD stuff that the uninstall didn't pick up .
Edit : just read past my last post and tethlah said it already
Old November 26, 2012, 05:53 PM
You see, if I remove the card, I can't uninstall the driver if I don't have a card in.
I don't have a dvi/hdmi/vga port on my motherboard =p
Old November 26, 2012, 06:15 PM
Enable integrated graphics, uninstall drivers, shutdown computer,remove the card,install the new one,reboot,install drivers, end of the trip
Question about sound card placement in relation to video card. QuiZNo Audio 5 January 18, 2012 01:58 PM
Can you mix brands of RAM? fireXtract RAM 4 December 19, 2011 02:42 PM
Same card, different brands, different performance? DRYJESUS Video Cards 11 December 29, 2010 12:55 PM
Psu brands what to look for? upcoast604 Power Supplies 45 March 12, 2010 12:28 PM
Question about switching from Nvidia to ATI tri5cui7 Video Cards 3 January 18, 2010 01:52 PM
