Old November 22, 2012, 07:00 PM
r0k0's Avatar
Default 7970 or Xfire 7870 ?
im thinking of selling my 5970 with EK WB and buying either a 1x 7970 for my i5 or 2x 7870 in xfire
which is best ?
Main Rig
Intel Core i5 2500K - 5.0
Asus Maximus Gene-Z / Gene 3
4x 4GB Corsair Vengence DDR3-1600
AMD Radeon HD 6990 4GB 880 / 1300
Crosair 600T White / Enermax Revolution 920W
A-DATA 120GB SATA3 SSD / Seagates 1TB Spare SATA3
Canadian Eh ?
Old November 22, 2012, 09:18 PM
dandelioneater's Avatar
Since you have a 23'' monitor I'm assuming it is 1080P. A 7970 might be overkill. I'd look at getting a single card first. Maybe a 7950 or 660Ti even. Then when you need more juice you can add a second. I wouldn't go straight to dual cards. I've always felt let down by SLI/Xfire. There's usually driver issues for new games and its useless if you play any games that don't support dual cards.
Old November 23, 2012, 12:42 PM
7950 is a beast for the price BUT nvidia tend to do better at the lower (1080) resolutions than ati.. also faster to market with sli profiles etc.
1 card is plenty unless your going 3d or 120hz etc.., 660ti 670 7870 7950 pick one and be happy.
Old November 23, 2012, 01:48 PM
r0k0's Avatar
I dont get it since when a card is overkill for fps ? And yeah 23" i have a tri-fire setup atm and going to 1 7970 would be overkill ?
Main Rig
Canadian Eh ?
Old November 23, 2012, 02:00 PM
BlueByte's Avatar
Since probably a generation or two ago??? Single mid level cards will push 1080p at 60fps no problem on most games. No point in going over that for single monitor setups.... You start moving into single 27"+ monitors or multi-monitor setups you buy the biggest cards you can afford to drive them.
Old November 23, 2012, 02:38 PM
GT7R's Avatar
Just get a single 7970 and be happy, should keep you going for a while.
Old November 23, 2012, 07:14 PM
r0k0's Avatar
That's what i was asking 1x 7970 or 2x 7870
So i guess i'll get the 7970 :)
Main Rig
Canadian Eh ?
Old November 24, 2012, 01:18 AM
Hardware Canucks Reviewer
As a general rule of thumb, go with the best single gpu solution possible. Throwing multiple cards together can often lead to issues that you don't want to deal with.
PowerColor Radeon 7870 2GB uberness Price Check 3 June 27, 2012 01:02 PM
ok. Need an opinion. Either a 7850 or 7870 ern88 Video Cards 23 April 12, 2012 04:00 AM
Anyone purchase the HD 7870??? ern88 Video Cards 4 March 28, 2012 11:21 AM
7950 vs 7870 16eiverse Video Cards 5 March 7, 2012 02:15 PM
Upgrading from GTX 570 to Xfire HD 7970's today - Questions ELCID777 Video Cards 10 January 24, 2012 05:39 AM
