Old November 21, 2012, 04:47 PM
Default Are nvidia 500 series blower cooler loud?
I'm a silence freak and the blower cooler on an EVGA gtx 560 ti 448 scared me away. Is the cooler quiet under normal load? Does anyone have one?
Old November 21, 2012, 05:09 PM
stoanee's Avatar
Define normal load? As soon as the fans on my 560 hit 50% they start getting noisy.
heatware
Old November 21, 2012, 05:35 PM
by normal load I mean putting the fans on auto (or setting a fan curve), then noise at idle and when playing games at a decent temperature
Old November 21, 2012, 05:43 PM
I heard that the EVGA fan is noisy...On idle it's probably quiet.
stoanee's Avatar
I suppose they will get noisy then.
heatware
Old November 21, 2012, 06:39 PM
supaflyx3's Avatar
My 560ti is really loud while gaming.
Old November 21, 2012, 07:13 PM
Thanks, helped alot
Old November 22, 2012, 07:31 AM
Unless its an oversized blower fan like some HIS cards use or the one used on the gtx690, it will get noisy under load unless you control the %. The type and size of fan a blower is as well as the backpressure against the congested rads they usually use, either its a loud enough whoosh or a leafblower type sound. 46%-62% seems to be the best range for most of them, otherwise they get crazy like.
Old November 25, 2012, 03:02 PM
my gtx570 fan I could barely hear while gaming
Old December 12, 2012, 08:56 PM
GTX 570 DCUII it was silent under 100% load.
HeatWare: http://www.heatware.com/eval.php?id=83342
NVIDIA 7xx series?? GT7R Rumor Mill 77 March 5, 2012 02:38 PM
How is the 200 Nvidia series GPU running for everyone? Jared11 Video Cards 2 September 30, 2011 09:20 AM
How loud is too loud for fans? Liu Kang Air Cooling 40 April 5, 2009 10:11 PM
LF: VGA Cooler for HD 3800 series darksideleader Buy/Sell & Trade 0 July 5, 2008 01:18 PM
NVIDIA's GTX 200-series Specs Revealed Hardware Canucks Press Releases & Tech News 0 May 21, 2008 10:57 AM
