Old November 15, 2012, 07:57 AM
wirerogue's Avatar
Originally Posted by SKYMTL View Post
What are your overclocks like?
it does 1300mhz easily enough. works fine in all my games and benchmarks except for the unigine heaven benchmark. i get some artifacting at 1300 even with the voltage maxed out. so, for every day use, i run it at 1275 with 1.3v at 100% LLC. i bumped the memory speed up 6700 with no increase in memory voltage.
this card overclocks great for dummies like me that aren't very good at overclocking.
a small issue with the new version of ASUS GPU Tweak 2.2.8 off the ASUS website. it wouldn't correctly monitor GPU usage. so, i went back to 2.2.12 that came on the driver cd and it worked fine.
even when overclocked, temps rarely get above the low 60s under full load.
so far, i am very happy with this card.
Old November 15, 2012, 09:22 AM
Originally Posted by BlueByte View Post
I would be interested in crossfire temps, my two Asus DCII's are so tight with 3 slots that the trapped card get really hot. I am probably going to put a couple of 120s on the top of the cards to help out. Ticked me off to be honest since I went for silence.
The only problem with the dcuII as opposed to say, a sapphire toxic phase change cooler is the exhaust doesn't get channeled out of the case as much. There is a whole lot more hot air being blown off the card and into your case.
I think the best approach is to have a good exhaust fan (cpu exhaust fan) and then make sure there is strong positive pressure in the case.
If you can put a large 230mm fan, or a couple of 140mm/120mm fans right over the video cards it should help a lot.
Could you possibly post a pic of your rig? I have only seen one rig with 2xDCUII cooler cards and it looked awesome.
Old November 15, 2012, 10:30 AM
GT7R's Avatar
Wow. What a huge impact AMD did with their latest drivers... Kudos to them, hope it ain't gonna be a one-off.
Old November 15, 2012, 02:18 PM
BlueByte's Avatar
I posted a pic in the case thread
Case Pics
Yes these cards do not exhaust as much as they should, and the back plates get hot even with decent air flow over them. right now with a custom fan profile 100% fan will keep the cramped card at 77ish. 100% fan speed is not my idea of tranquil though. I have put a small rubber foot between the two cards and screwed them in such a way to allow the largest gap between the cards. I should have gone with gigabyte cards to allow for a full slot space between the two. but I was sucked in by marketing of 3 slot massive coolers. There were a few other problems with the TOP cards as well, voltage locking
Old November 15, 2012, 04:59 PM
NyteOwl's Avatar
Performance is impressive, but if these things keep getting larger and hotter they'll be encapsulated in heatsink and require they own case.
Obsolescence is just a lack of imagination.
Old November 18, 2012, 07:33 PM
IRQ Conflict's Avatar
Ugh, they can't keep these things on the shelves. It sure is a great deal.
I want to die peacefully in my sleep, like my grandpa. Not like the passengers in his car, screaming and crying.
Old November 20, 2012, 11:23 AM
elmorejohn46's Avatar
I like the ASUS heatsink Direct II CU because it is quiet even if it is running at a 100% and if you have a good cooling case ,it doe'nt build up that much heat.
Intel-i7-3820+Corsair H-100+Gigabyte X79-UD5+16g G.Skill 1666DDR3+256g Crucial-SSD+1-3TB Seagate+2-1TB-Samsung+1-640g- WesternDigtal+SLI-ASUS DIRECT CU II GTX-670+LG-12x Blurner+Logtech G9x-mouse+G-110-keyboard+Driving Force GT Wheel+Pioneer VSX-1020K+Polk Audio Speakers+LG-50"Plasma PM6700+Antec-P280+XFX 850w PRO Semi-Modular
AMD Radeon HD 7970 GHz Edition Review Comment Thread SKYMTL Video Cards 16 June 27, 2012 12:32 AM
ASUS RoG GTX 580 Matrix Platinum Review Comment Thread SKYMTL Video Cards 17 August 19, 2011 08:30 PM
ASUS HD 5870 Matrix Platinum Review Comment Thread SKYMTL Video Cards 13 June 6, 2010 07:38 AM
