-   -   4 monitor setup - Need help (http://www.hardwarecanucks.com/forum/video-cards/57731-4-monitor-setup-need-help.html)
Pabz0r545 November 6, 2012 08:10 PM
So my brother wants to do a 4 monitor setup. He programs, does web development, runs a server and monitors stock market among other things. He also games and wants to have the option to multi monitor game but it is not priority. He has never used a 2560x1440 and neither have I but I am thinking bigger is better and I am trying to push this resolution on him since he can afford it and it sounds to me like he wants the ultimate setup(plus it will be fun for me). There is no budget in mind but obviously we want a good bang for our buck and will not just go ridiculous with it. Should he be going 2560x1440 x4 or is 1920x1080 x4 enough? He wants 3 on the bottom and 1 on top all in landscape.
Help us pick the right cards and monitors. 7970 crossfire?
BeaverBender November 6, 2012 08:26 PM
How much space does he have? The reason I ask is that if he truly wants 2560x1440, he is looking at 27" or larger screens, at least that I'm aware of at present, so he will require a lot of desk real estate. If he does go for that res, I would say the HP zr2740w is probably the best bang-for-the-buck at the moment... Mfr. Part Number: XW476A8#ABA.
bliz November 6, 2012 08:39 PM
If you don't have budget limit, it depends, for everything but games you can take the 2560x1440 but if you play with them i hope you have also 2000$ to spend in GPUs,because FPS on those big resolutions suck, and MULTI MONITOR,means you will need 2 monster GPUs , 1 DVI and HDMI on each card i guess... 1080p is very good and seriously, i don't see why buying those big resolutions, better image of course but when you play it's not much different.. if you have AA x16,no need... and it will be 4000$ in the monitors i guess,unless you buy super cheap panels.. not worth the price.i vote for 1080p
PS: 120hz for 2560x1440 are horribly expensive and it's not worth the price,i think a few overclocked screens do that, i'm not sure,what is sure is that most 2560x1440 are 60hz
Ok if you wan't 4 super high quality panels that will piss of your computer and your GPU, take dual 680 ,because it's faster and overall, a 680 is better and generally cooler and ... more expensive of course..and anyway i prefer nvidia ,Making GPU's is their job and the drivers are better..
But seriously, when you buy a 2560x1440 it is generally for single monitor^^
Finally ,i say that 4 2560x1440 are NOT WORTH THE PRICE AT ALL because you will need way better GPU's just for a little better image.. seriously, throw AA x16 or 32 if you want and it will almost be the same for 2x cheaper.
Pabz0r545 November 7, 2012 05:43 AM
Thanks for the responses guys. Much appreciated.
He has pretty much an unlimited space. He has a very large room in use for his computer room. He will either have a desk custom built or will find the biggest one he can. We are aware of the space it would take up. I will look into that monitor for sure. Last night I looked into the famous Yamakasi Catleaps and they run around $400 so that would be very affordable.
Bliz like stated triple monitor gaming is not a priority. At the moment he doesn't even play any games that support triple monitors but he wants the option in the future in the event he finds a game he really enjoys that is triple monitors. It is more for work then anything. He always has multiple programs open while he is coding and likes to have a tab or 2 of google open among other things like monitoring stocks. 2 monster GPU's is no problem. I told him he better be expecting to pay upwards of $2500 for his gpu's and monitors and he said that is fine.
We will discuss the 1080p option and I will try to get him to a store where he can view a 2560x1440 to see the difference. I realize it may seem silly to you but he really really wants all the monitor space he can get for work. 4x 24" 1080P SHOULD technically be enough but he said "Maybe I will just ball out and go all 2560x......" Both options will be explored though. Thanks and I appreciate your opinion. 120hz is by no means a requirement here, 60hz is fine. Again gamin is only secondary or tertiary.
I prefer Nvidia myself but we are not partial to any company. I guessed the 7970's would be the proper choice because of the extra vram and I always see people say AMD is the way to go with extreme resolutions. Your advice will be taken into consideration on the 1080p's. Thanks a bunch :D
Cheers
I would love some other input from anyone who has multi monitor setup.
Arinoth November 7, 2012 06:39 AM
Going 2560 x 1440 is going to take up a lot of space and may be overwhelming size wise since I believe 27" monitors are the smallest where you can go with that resolution and be able to read/see everything with enough detail to make it worth it. I have 1 27" monitor and it takes up a lot of space, if you are doing 3-4 you're going to need to sit back further then normal to be able to see even most of the screens at the same time.
Pabz0r545 November 7, 2012 01:38 PM
Ok I thought 2560x1440 was cool but it seems as though it will just be way too much. What do you guys think about dual 2560x1440 vs 4x 24" 1080p?
Perineum November 7, 2012 02:00 PM
Just an FYI, but a triple setup with 22 inch monitors is around 5 feet wide.
I would do 4 22" monitors and then run them off of single or dual 680 / 670, with the dual being better but more expensive of course.
Nvidia supports a 4th monitor for misc stuff while gaming on your triple setup, as far as I can remember. I think the new 6xx series cards support 3 or 4 monitors out of the box as well.
Pabz0r545 November 7, 2012 02:06 PM
Thanks for the heads up Perenium. A massive desk will be purchased or custom built for this.
Hrmmm 680 lightning?
mleunm November 7, 2012 02:12 PM
why break the bank?
i'm happy with my 3 16x12 monitors in portrait mode on a monitor stand
using an amd/ati 6950 will add another for crossfire during the holidays after i upgrade my cpu
bliz November 7, 2012 02:35 PM
Man ,the best would honestly be triple 24" 1080p. with 680. performance for price.. lighting? why? its more expensive.. want to overclock? enough performance with stock speeds... a gigabyte or an asus is cheaper and will run great...a 670 SLI is also a very good idea, destroys 680 and it's not that expensive if you buy gainward... or best is dual 670 from MSI :clap: :clap:
