-   -   For the 10000000 time its been asked. (http://www.hardwarecanucks.com/forum/video-cards/57706-10000000-time-its-been-asked.html)
Chromey November 5, 2012 03:08 PM
Is it time to upgrade the 580GTX?
Dont think ATI is they way for me, But is the 680 really that much of a upgrade?
For the most part it looks like a 20-25% increase at best.
Run SLI or
Buy a 680/7970?
Wait for the 685?
Let me know what you think.
BTW
I play FPS/RPG Newer/Newest games only.
I play at 1920-1080
JD November 5, 2012 03:14 PM
Are you having issues playing games at 1080p with a GTX580? I highly doubt it...
I wouldn't bother upgrading.
Chromey November 5, 2012 03:34 PM
Not issues But the question is....IS it time or wait?
Arinoth November 5, 2012 03:34 PM
It isn't time, you should wait.
sswilson November 5, 2012 03:52 PM
If used 580s were making any kind of cash it might be worthwhile, but they seem to be stuck around $250 at best so IMO it's not really worth it.
Bond007 November 5, 2012 03:56 PM
Wait IMO.
Chromey November 5, 2012 04:01 PM
Thanks a bunch Guys, Needed the extra help with this one...Ill hole out untill needed.
The 930 running at 4.2 Still pulls ass, So i dont think a CPU update is needed anytime soon.
JD November 5, 2012 05:31 PM
I think a platform upgrade would be more beneficial though if you have the "upgrade itch".
It would get you SATA3, USB3, PCI-E 3.0 and UEFI. Better power efficiency too.
If you don't have a SSD, I would strongly recommend buying one of those. That's the most noticeable upgrade I've ever done.
Soultribunal November 5, 2012 06:42 PM
This is probably the best set of advice there is for this.
-ST
JJThomp November 5, 2012 07:20 PM
Also they are making the 780 out to be the next coming of Christ so I personally I would wait, not gonna see a difference on 1920x1080 because 580's still crank it out easy.
