Old October 23, 2012, 12:17 PM
Default Is that noise dangerous?
Hi guys,i never worried about that noise, i have had it for 1 year and my card works perfectly,and it's not very loud but i was wondering if it's normal of if the fans will die soon? the microphone is very close to the case so ,it's loud,but actually, not that loud, here the fans are 80% .
It happens when the fans are 70-80% electronical noise.. It's not a problem for me ,I use headset but well ,if it's dangerous for the card..(recorded with extremely High end mic so it's the exact noise.)
GIGABYTE WINDFORCE GTX 570.
Tests: the card or the fans are not vibrating(when i touch the plastic of the card) when the noise happens, everything seems to be stable in the case, happens more when changing the power of the fans,from 0% to 80% with afterburner,seems to be purely electronical.
What i want to know is : can it damage the fans? my PSU is good.
Started before i overclocked the card,a year ago.
The fans move normally but i listened to a lot of coil whining vids,sounds like that.And the noise seems to come from the electronics and the PCB itself.Even if it depends on the fan speed, seems to come from near the power connectors but inside the card
EDIT: there is also a slower cracking noise at 50% fans
Old October 25, 2012, 03:27 PM
If it is indeed coil whine, then it is harmless. It sucks, but it seems that it's a very common issue with higher end cards that draw a lot of power.
This may not be of any comfort to you, but that's actually quite mild in terms of how severe coil whine can be. From my experience, they vary from a mild buzz to a high-pitched squeal. Yours is the quieter buzz variety, and may or may not get better with time.
If you're feeling particularly adventurous, you can try the nail polish method to try and alter the vibration pitch of the coils.
Old October 25, 2012, 03:58 PM
KaptCrunch's Avatar
add a filter (bi-polar cap) on fan motor
Old October 25, 2012, 07:09 PM
Thanks,but i prefer to leave my card alone^^ I would break it, actually it is not that disturbing while playing,as long as it does not explode :D
and i only have it in a few demanding games ,so..
Old October 25, 2012, 09:56 PM
NyteOwl's Avatar
Some people have had luck in putting a small dab of hot glue on the offending coils. I've not tried this myself so this is entirely anecdotal.
Obsolescence is just a lack of imagination.
Old October 26, 2012, 11:33 AM
Shadowmeph's Avatar
Wow I never heard of that it is nice to know if I ever run into a problem again.
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Old October 26, 2012, 11:36 AM
supaflyx3's Avatar
Nail polish also works.
Old October 26, 2012, 11:57 AM
CroSsFiRe2009's Avatar
Coil whine should become more noticeable when the card is under load like when you run a stress test. I'm not sure if you're just manually cranking up the fan speed or if you meant the ramp up when gaming. You can always stop the fan while under load for a few seconds if you're feeling particularly adventurous. If the whine is still there, then yes, it's bad caps but you can't do much about it short of nail polish or asking for rma
Old October 26, 2012, 12:25 PM
great_big_abyss's Avatar
Hmm, Nail Polish trick, eh? What do you do? Just paint the tops of the caps with a little nail polish? My 295 has very bad coil whine.
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; Sapphire HD5870; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; ASUS GTX650Ti Boost; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
Old October 26, 2012, 01:06 PM
NyteOwl's Avatar
No you put it on the coils, not the caps. The idea is that the coil winding oscillate ever so slightly and you are essentially "gluing" them to the cores. I persoanlly wouldn't recommend nail polish as it typically contains acetone which is a very efficient solvent and will do a "nice" job on plastics, circuit board ink printing, and even in some cases the enamel coating used on the coil windings.
MicroBytes Armed and Dangerous Llew Canadian LAN Parties & Events 98 May 18, 2011 11:16 AM
120v outlet filter for noise, such a thing? (popping noise from speakers) On2wheels Troubleshooting 3 June 20, 2010 08:06 PM
Dram voltage 1.79 dangerous? Chris RAM 5 June 25, 2009 10:34 PM
Do I have any recourse for a dangerous trek into work? Cheator Off Topic 30 December 10, 2008 02:00 PM
ASUS MyLogo -- dangerous? CTA O/S's, Drivers & General Software 3 October 4, 2008 07:40 PM
