-   Video Cards (https://www.hardwarecanucks.com/forum/video-cards/)
-   -   3rd party vrm heatsinks (https://www.hardwarecanucks.com/forum/video-cards/57452-3rd-party-vrm-heatsinks.html)
geoc October 22, 2012 06:24 PM
I've always wondered are those dinky looking vrm heatsinks for videocard ever enough? I have a gtx260 under water right now, and I have cut the vrm section of the stock heatsink and kept it on the videocard, unfortunately the vrms are hitting 150C underload.
I have quite a few bga ramsinks and vrm heatsinks I could throw on, but I lack faith in those dinky little things keeping the vrm cool.
What are your thoughts on this matter?
stoanee October 22, 2012 07:00 PM
They actually do work, if you can keep them stuck on. I ended up scraping off the double sided tape & using a two component adhesive.
Arctic Silver Alumina Thermal Adhesive 2 X 2.5 Grams
botat29 October 22, 2012 07:09 PM
I use the same stuff
geoc October 22, 2012 08:08 PM
What percentage do you mix with thermal paste? I only have ceramique left, my AS5 ran out.
stoanee October 22, 2012 08:40 PM
You can use it as is, without mixing with thermal paste. Try experimenting, I believe that by mixing in paste you lessen the strength of the glue.
geoc October 22, 2012 08:44 PM
I read online that if you use pure adhesive, you can bet it will never come off (should I decide to remove it in the future). Mixing it with paste allows you to remove it in the future if you choose to while maintaining a decent amount of adhesive strength. Did you just straight glue them on?
stoanee October 23, 2012 07:21 AM
Yes I did and they came off fairly easily when the the card was still warm. I would do some test samples to verify that.
botat29 October 23, 2012 08:25 AM
it's epoxy , so you mix 50/50 the 2 alumina tubes
geoc October 23, 2012 11:29 AM
Thatswhat worries me, I don't want to jb weld the heatsink onto my card haha
