Old October 15, 2012, 02:24 PM
Exclamation GTX 650 non-ti Overclocking
I have a GTX 650 non-ti from gigabyte. I have overclocked it a bit, but a lot of the times fps drops a lot and i don't know what to do. Do anyone has the same issue? Someone tell on what memory and core clock are you running on?
Old October 15, 2012, 03:06 PM
If FPS drops,you have overclocked it too far,i have experienced that on an old card,the games even put in on pause automaticly,or sometimes, just lags for 5 sec and is normal again.
Raise core clock while running furmark,then raise voltage when having artifacts. If it overclocked properly ,should not have issues.CHeck the temperatures?
What do you mean by "a bit"
Clocks are different for any user,depends on many things... Don't just find a result on the internet and boom,overlock it like this,won't work,you can to find your setup by doing it carefully, core-voltage-core-voltage and temps..
The memory clock is usually quite useless, you can touch it a bit but i didn't have a gain of 1FPS for my card.. idk for this one, i suggest you don't overclock the memory and see if it still slows down,also check the clocks when you have this bad FPS, windowed mode in game and see the clocks, if they stay same when lagging
It's drops only since the overclock or before and after?
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old October 15, 2012, 09:57 PM
After the overclock.
Old October 16, 2012, 04:02 AM
Sounds like its throttling. What temp is the card under load? Use MSI afterburner to find out.
Old October 16, 2012, 05:56 AM
Idle - 29C Load - 58C
Tags
gtx 650 overclocking gpu
i7 970 overclocking Brian@NCIX Overclocking, Tweaking and Benchmarking 6 March 18, 2011 08:25 PM
GTX 480 Overclocking ImmaPC Overclocking, Tweaking and Benchmarking 24 March 13, 2011 06:36 AM
i3 530 overclocking fun Realityshift Overclocking, Tweaking and Benchmarking 11 May 29, 2010 04:40 PM
Overclocking Help Plz appplejack Overclocking, Tweaking and Benchmarking 3 January 4, 2009 10:50 PM
Overclocking help tzetsin Overclocking, Tweaking and Benchmarking 41 January 27, 2008 11:05 PM
