-   -   Dual graphics with Radeon HD 6670 (http://www.hardwarecanucks.com/forum/video-cards/57136-dual-graphics-radeon-hd-6670-a.html)
boggy_b1 October 8, 2012 12:21 AM
Hi,
I just bough this video card to crossfire it with the A8-3850 integrated graphics. As it is pretty complicated to setup the crossfire and AMD doesn't give you any advice I've watched some videos and read a few tutorials so I can make it right.
I think I managed to setup the crossfire properly but it seems it doesn't work. I'm saying this because the Windows 7 benchmark haven't changed at all. I've got same 6.8 for only using onboard graphics, or the dedicated 6670 alone or both APU and discreet card in crossfire. Also in-game FPS are the same.
Do you have any idea of how to solve this issue or any other way to check if the crossfire is working.
Thank you in advance!
MARSTG October 8, 2012 09:21 AM
maybe reading the review again would help? technically speaking the crossfire setup should be automatically detected by the Catalyst driver upon reboot and you would be invited to allow the combination to be done. And that would be the most of it. Or this is what I had when crossfiring the discrete cards.
http://www.hardwarecanucks.com/forum...desktop-7.html
Arinoth October 8, 2012 10:18 AM
You can't crossfire the 6670 other then with another 6670. It sounds like the OP wants to try to crossfire his 6670 with the APU in the A8-3850 which you cannot do.
dARqSyDE October 8, 2012 11:55 AM
You might have to change a setting in the BIOS. I know I had to with mine.
Also, check the settings in Catalyst, make sure the box is checked, and don't forget to download the latest CAP.
WEI doesn't accurately reflect the Dual graphics rating, AFAIK.
boggy_b1 October 9, 2012 12:25 AM
Thanks for the review, I've read a lot but this one I've missed. Anyway as we can see in this review the dual graphics between A8 and 6670 should improve in-game FPS which does not happens to me. Moreover my video quality and FPS are better when I use the dedicated HD6670 alone as the primary display device. I don't think this is normal.
Thanks for the reply but I beg to say different. Please see AMD Radeon Dual Graphics
Here's what I've done:
- With the 6670 not plugged in I've setup BIOS to use the primary display graphics ONBOARD
- Installed the latest AMD Catalyst (12.8)
- Plugged in the discreet card and put monitor cable from onbord DVI to the dedicated DVI
- Enabled in Catalys the AMD Dual Graphics option (there is no Crossfire option only this one)
With all this I don't have a check box in Catalyst, here's what I see:
http://imageshack.us/a/img849/4861/lc9iq.jpg
boggy_b1 October 10, 2012 01:58 AM
Here is what steps I followed to setup the dual graphics:
- With the 6670 not plugged in I've setup in BIOS: - Init Display First to Onboard
- Setup in BIOS UMA Frame Buffer Size to 1024MB
A screenshot of the Catalyst after this steps were done:
As you can see there is no crossfire box because it's the latest driver. Could this be the problem?
boggy_b1 October 10, 2012 01:59 AM
jepetaye September 29, 2014 05:35 PM
APU A8 A3870k + hd 6670 + Asus F155-M (dual graphics compatible)
My Bios configuration :
In " NB CONFIG "
IGMFX ... : disabled
Prim vid dev ... : IGFX Video
Int. graph : force
UMA... : Auto
HDMI/DVI : auto
(to acces bios press delete repeatedly while booting)
Few steps (this is what I did, after several hours of failure and swearing :) :
1- Remove the descrete video card and plug screen on Mother board
2-Remove drivers , instal CCleaner (clean up + registry clean up)
3-Instal the descrete video card (hd6670 works fine with a8 3870K)
4-Instal the CD driver that were in the box with the descrete video card
Well, some of these steps may be useless, I don't know, but when I didi this, it worked.
