-   -   Really weird SLI issue... (http://www.hardwarecanucks.com/forum/video-cards/57041-really-weird-sli-issue.html)
mattlef October 2, 2012 06:25 AM
Hey everyone
As you may have seen, I've aquired a couple of 660ti's and have thrown'm together in SLI.
I have, however, encountered a problem. When playing BF3, (have yet to test other games) in full screen, with SLI enabled, (both gpus go to 80-99%) the screen has this horrible flicker and purple overlay. However in windowed mode, BF3 plays perfect.
However when i change the sli profile to rendering with one card, the game plays pefect, but only off one card (c1-99%, c2 15-35%)
Is this a driver issue? or, am i doing something wrong? I have no idea what to make of it.
Power issues wouldnt cause this problem would it? I'm running right now on a gold rated Seasonic X-660 psu.... so i should have more than enough headroom.
Thanks!
-Matt
Skyllz October 2, 2012 06:30 AM
Completely oddball solution but it worked for me with my 260GTX back then when I had weird rendering issues...
I swapped the cards from one slot to the other, used a different SLI bridge and the problem went away. The cards were probably not seated right.
lelionmoddeur October 2, 2012 06:36 AM
maybe its a damaged bridge, try to use another,or maybe it's badly pluged
mattlef October 2, 2012 06:41 AM
I'll give that a shot.
Would that really affect fullscreen gaming though, like wouldnt that be the case in the desktop too?
I'll try reseating when i get home tonight. hope that actually helps.
lelionmoddeur October 2, 2012 06:48 AM
maybe there is some dust on the connector,try to blow in the stuff
happened with my nintendo DS lite:whistle::bleh:
there are generally protections on the SLI golden thing ,on the card,if the protection was removed for ages,a simple blow may fix your bug
botat29 October 2, 2012 06:50 AM
I have the same problem with a 2 x 560 , I just switch the monitor cable on the other connector of the same card and it's work well now.
3.0charlie October 2, 2012 09:24 AM
With an X660, I'm not convinced that power is not an issue.
http://www.hardwarecanucks.com/forum...xy-msi-22.html
and
AnandTech - The GeForce GTX 660 Ti Review, Feat. EVGA, Zotac, and Gigabyte
Both show ~300w for a single card. I can imagine that running SLI will hit the 600w mark, add the CPU and you will push your Seasonic past its limit.
Ajiki-kun October 2, 2012 09:38 AM
Are you using Afterburner?
If so, then disable "Synchronize settings for similar graphics processors".
mattlef October 2, 2012 09:42 AM
and
Both those values are total system. with the cards in SLI I'd assume they'd pull about 200-250 each.
CPU and components would pull 100-150, meaning im within the power threashold of the PSU.
I will be upgrading, but im not 100% convinced that power is the problem.
SKY uses the following for reviews:
Processor: Intel i7 3930K @ 4.5GHz
Memory: Corsair Vengeance 32GB @ 1866MHz
Motherboard: ASUS P9X79 WS
Cooling: Corsair H80
SSD: 2x Corsair Performance Pro 256GB
Power Supply: Corsair AX1200
Monitor: Samsung 305T / 3x Acer 235Hz
OS: Windows 7 Ultimate N x64 SP1
The 3930 @4.5, ram and mobo will pull a hell of a lot more from the PSU than my 2500K, 8gb @1.65v and mobo...
so for one card, I'd estimate the draw with one card to be around 260w, add another card, I'd assume 450-500 tops, then add in my pump, and fans... which are pretty much nothing, and boom... within the envelope.
Toms review of two 660tis shows draw as the following:
http://media.bestofmicro.com/9/I/348...inal/Power.png
Ajiki-kun October 4, 2012 12:37 PM
Did you manage to fix the problem?
