Old October 1, 2012, 07:39 AM
Default Installing R7950 3GB PLEASE READ
Hello everyone,
Recently my RMA Replacement MSI R9750 3GB OC Graphics card came in the mail. Before i hook it up ( to avoid any problems ) i want to make sure I'm doing this correctly.
I have a tx 650 m power supply from corsair. I know this can power it because it all went fine until one day (long story). Took hook it up should i use these two black cables included with the PSU? On one end there are eight pins and the head of the cable is blue. On the other end there are six pins. One of them however has eight pins on the black too but with two of them detachable. Should i just hook the black ends to the card and then the blue to the power supply (both cables directly)? I just want to make sure i don't do anything bad. Thanks guys!
Old October 1, 2012, 07:54 AM
lelionmoddeur
Guest
Posts: n/a
the tip with only one connector is in the power supply, on the other tip you have 6pin plus 6+2 pin right?
if your card needs a 6 and a 8 pin,plug the 6 pin and the 6+2 as a eight pin,but the single plug ,8 pins is for the PSU!,the several connectors are for the card :)
http://techreport.com/r.x/psus-0907/pcie-connectors.jpg
use those tips for the card
a card needs only one cable,plugged into the PSU as PCIe1 ,generally
blue,for PSU,black,for card! in your case
you will see it's easy :)
Old October 1, 2012, 08:04 AM
One cable only? Im reading on the manual here
System requirements:
600 watt or greater power supply with one 75W 6-pin AND one 75W 8-pin pci express power connectors recommended.
Old October 1, 2012, 08:11 AM
lelionmoddeur
Guest
Posts: n/a
yes,one cable separated in 2 connectors, one that is 6 pin and one that is 6+2 ,i mean its a cable like this :D
GPU
Y
PSU
so it's one cable overall,plugged in a PSU,but separated in 2 connectors , 6 + (6+2) for the card!
if you want,my picture is what you need for video card connexion,but those 2 cables are like "Y" this shape
and one thing in the PSU :)
Old October 1, 2012, 08:26 AM
GPU
Y
PSU
Im so sorry i feel really stupid right now, can you post a picture? Are you saying i need to only use one cable and use a splitter and splits into two ends and those two ends plug into the GPU?
Old October 1, 2012, 08:37 AM
you need to figure out what are your pci-e cables and for from there and the manual will help greatly with this.
But generally pci-e connectors will be a combination of 6 pins and a 6 pin with an extra 2 coming from the ground on the cable. I for radeon cards its advisable to use the 6 and 8 connectors to work properly.
Old October 1, 2012, 09:07 AM
Okay here are the pictures (old ones):
Plug that into the eight pin socket and get the same identical cable except it has 6 pins and plug in that into the 6 pin area? This means two cables and no split.
into the PSU:
Old October 1, 2012, 09:14 AM
yes exactly 2 cables. 1 8 and 1 6
Old October 1, 2012, 09:16 AM
Okay sounds good, im just scared im going to blow something :(
Old October 1, 2012, 09:18 AM
cables can only fit one way
R7950 OR GTX660 Ti PcWizTech Video Cards 4 September 24, 2012 10:05 PM
Books to read? Polygon Off Topic 16 October 27, 2010 04:52 PM
can ms-dos read usb? CTA Off Topic 2 August 19, 2008 03:29 PM
Problem trying to get 'Read Only' file not Read only! bushwickbill Troubleshooting 5 August 10, 2008 12:41 AM
