Old September 23, 2012, 05:03 PM
Default When to rma a 7870/7950 videocard ? (update responce from powercolor rep)
So, while troubleshooting my pc's weird stability issue's while playing alot of my 1 game I got alot of what is called now GSOD (grey screen of death) though it doesnt occure in any others.
Thru googling recently I have discovered that this is occuring in alot of the 7870/7950 series cards & through the various postings someone has put all the facts together & drawn a factual conclusion that the gsod's are occuring on these cards cause of bad memory overclocking. Those users whom get the gsod's whom backed off on there ram overclocks or brought them back to stock speeds had there gsod's go away.
My question then is .... IF the card doesnt artifact or cause system lockups when specificaly the ram is @ default or slightly oc'ed settings .... would this be a basis to STILL rma the card cause of its ability to not overclock the rams speed much past default settings on it without causing issue's or lockups. Or do you simply just gotta call this a card built with sub par moduals on it?
thanks
Old September 23, 2012, 06:18 PM
Your_friendly_gamer's Avatar
Just rma the card and give the new card a try.
Old September 23, 2012, 06:57 PM
Soultribunal's Avatar
Now just so I understand, you have OC'd the memory beyond factory spec or what you got the card at correct?
If that is the case, no warranty promises what type of OC you get, and given that only one game does it, it might be that game demands different resources from the card.
I would say it wouldn't have much a point in RMA'ing a card based on that.
-ST
www.realhardwarereviews.com
Old September 23, 2012, 08:45 PM
Agreed - unless the card specifically says an overclock that'll be guaranteed stable on it (which never happens as they'd just ship with that OC anyway) there is nothing you can RMA about.
Besides, isn't a 7870 bottlenecked by its core before it's ever bottlenecked by its memory bandwidth anyway? Unlike low-end GDDR3 cards, you may be better leaving the memory at stock and OCing the core at bit more with the TDP capacity that you "saved".
Old September 23, 2012, 10:49 PM
-ST
True, but here is my concern/issue ..... I go to re-sell this card say that I dont think its giving me enough preformance to upgrade to a higher end card, person gets it & starts experiencing the same issue's I have ... Then im seen as a "bad seller" cause im selling a "faulty" videocard ...
Old September 24, 2012, 05:10 AM
So?
If I sell my i5 2400 and you can't get more than a 200mhz OC on it is the Chip bad?
Nope. OC'ing in the world is a YMMV situation and would not make you a bad seller unless you said "OMG Buy This Card, Capable of 1200MHZ CORE/RAM"
So long as the Card runs perfectly at the settings from the Factory you are fine.
-ST
Old September 25, 2012, 02:04 PM
Default (update) responce from powercolor rep
So I thought i'd update this as I just got this 2nd reply from Mr.Jonathan Garay a power color rep in california:
" The limitation on OCing is to make sure you donít do it so high that you end up burning the PCB ;-). Basically, no physical damage and apply the OEM BIOS of the card (if the card is not entirely dead). You can swap out the cooler for an aftermarket cooler as well, just be sure that if you need an RMA that the original cooler is back on. If you have (or will be doing so in the future) be sure to properly handle the card to avoid accidental physical damage to the PCB.
And yes, you can send us your card for an RMA if all is otherwise good with the card J.
Thank you,
Jonathan Garay
Jonathan Garay | jgaray@powercolor.com
1216 John Reed Ct.
City of Industry, CA 91745
Old September 29, 2012, 12:17 PM
Wait, you want to RMA a card because it doesn't OC high enough? No offense, but are you freaking serious? That is not ethical or a valid reason to RMA. That is ridiculous, even if a CS drone tells you otherwise.
My apologies if i'm misunderstanding.
Old September 29, 2012, 02:46 PM
no ..... if the card is having issue's from / since a oc .... then id have to rma it. BUT I am not shure if its the case or not .. cause like whomever said ... settings in 1 game it doesnt do anything, but in another it may crash. So in that instance it might be a driver/game issue n not a hardware issue. And my card has only been pushed thru the ccc overdrive so its not been overvolted or what not.
8850/8870 rumors on the net ... would you buy 7870/7950 now? terrybear Video Cards 13 September 23, 2012 01:26 PM
ok. Need an opinion. Either a 7850 or 7870 ern88 Video Cards 23 April 12, 2012 04:00 AM
Anyone purchase the HD 7870??? ern88 Video Cards 4 March 28, 2012 11:21 AM
7950 vs 7870 16eiverse Video Cards 5 March 7, 2012 03:15 PM
