-   -   Galaxy 680 GC 4GB bad? (http://www.hardwarecanucks.com/forum/video-cards/56880-galaxy-680-gc-4gb-bad.html)
FM2125 September 23, 2012 12:47 PM
I've been having lovely issues with my replacement 680. I had a 680 SOC that died which was a bummer because I had it to 1400+ and they replaced it with a 680 GC 4GB because they said they didn't have any SOC's in stock. On arrival the card came without the graphic box cover (just a black box) with a seal on the flap to open it. Card looked good. Plugged it in and installed drivers and finally got my computer running. Went to play BF3 and it let me spawn, run, then crashed. That was the farthest I have ever gotten with this card. After that it only would let me see the loading screen then the driver would crash. 3DMark 11 has bad artifacts and ghosting. Bad Company 2 has the same issue. I don't know specifically what it is buy I can only assume the card since I've never seen this before. Either that or my computer in general is just fubar. I'm in a tight spot with time so I guess now I have a very expensive internet browser device because it took me 2 months just to get some time to RMA my original card. I haven't heard any response from Galaxy at all after the decision was made to accept this card as the replacement versus wait an unknown amount of time for the SOC to replenish.
Aside from mini rant, does anyone have any possible solutions? I'm stuck.
Fail - a set on Flickr
supaflyx3 September 23, 2012 01:15 PM
Is the OC you had set to apply itself on a reboot?
Arinoth September 23, 2012 01:19 PM
Are you running the default fan profile, and how much air flow does your case have? If you are using the default go check out my signature to make a better one, and if you don't have much air flow a default fan profile will allow a card to overheat and artifact.
FM2125 September 23, 2012 01:24 PM
No I was using fully stock settings.
I have massive airflow in my case. Idle is 26 degrees under a custom profile designed to keep it under 70 no matter what. Doesn't go past 60 since nothing will run long enough to stress it. Forced furmark and left fans to minimum to see if heat made it worse. Stopped at 90 degrees because it did no change. Not even clock throttle (which I prefer, I never liked the 70 degree throttle with Kepler)
GT7R September 24, 2012 12:41 AM
If this happens while you're using WHQL drivers, I'd say you've got unlucky with a bad card again...
FM2125 September 24, 2012 02:04 PM
Yea that's what I figured. Well here's to waiting, again. This is unfortunate for sure. Haven't had a response yet either. I'll get in touch with the rep Andrew soon unless he beats me to it.
GalaxyTech September 24, 2012 04:51 PM
I'll share the images you posted with engineering to see what they suggest, but I can confirm the guys at the RMA department took extra time to test your card before sending out to make certain it performed well and met your expectations. I know with 100% certainty the card was working perfectly when it left, so unless it was damaged somehow during transit there shouldn't be any issues with it. Do you by chance have access to another machine to test it in? If I recall you still have a 2nd 680 as well, correct? Do the problems go away when you remove the new card and run the other one in the same slot?
FM2125 September 24, 2012 05:58 PM
I only have this card. The one I had before was the 680 SOC. And I believe it that the card was tested and am not faulting Galaxy for this. I don't have another computer to test it out in at the moment but I will see if I can over the next few days. Could this by chance be related to the PSU or even Windows? I would do a full clean install just to see if I can get all my data backed up properly before hand if that even had a chance of affecting it. I'll see what I can do about a new power supply as well.
Bond007 September 24, 2012 06:00 PM
Good to see the manufacturer involved on here. Hopefully everything will be resolved without issue.
Have you tried a different graphics card in your system to make sure its not something else causing the issues? Possibly power supply? What are the rest of your PC components?
Your_friendly_gamer September 24, 2012 06:43 PM
Its the card, I had similar issues with MSI, they kept sending me broken cards, they are usually, "refurbs". Not sure how these manufacturers test them. I think they are mostly returned.
I want to know how galaxy support tests a bad card? OR any other manufacturer. Anyways, MSI bumped me up to a 580 when I rma'd my old 480, and the 580 was sent twice as the first card had same issues as you. Artifacts.
I am sure Galaxy rep, it was tested before it left your place, but why is it artifacting? I dont think there are any other issues with the PSU etc, as those would cause other issues, not the drivers responding or the artifacts.
Or please list as the steps Galaxy takes to test a card before it's shipped out to the customer? Which programs are used to stress test etc?
Galaxy please pay for return shipping for this man, and send him a new card.
Thanks
