-   -   8800 gt problem in.....plz and thx (http://www.hardwarecanucks.com/forum/video-cards/5685-8800-gt-problem-plz-thx.html)
rob123 April 20, 2008 08:17 PM
i am running an asrock p4vm890 with a p4 2.8 processor.
recently i tried an asus 3850 and had to send it back for temperature issues. after awhile i got an asus 8800gt.
i just tried it tonight and nothing happened. the system will for some reason will not boot at all. the fan on the card is running so its getting power. i know i have an issue with pcie1 vs pci2 and this card is pci2.. however the 3850 was pci2 ( i am told) and for the while it worked it was fine.
i set the motherboard to go directly to the pci express slot and still nothing. another funny is that the usb keyboard and mouse are duff too. i think this has to do with the fact that the system is not booting up to the point where they are powered.
i have read many posts where there are troubles with the 2 versions of pci but havent found one where the system wont boot.
could i have a fried card from the beginning.
a sidenote. when i got the card from ncix it had obviously been opened ( the box). and the seal on the static bag had also been broken. not sure what to make of that.
any udeas welcomed
thx for your patience
rob123
sswilson April 21, 2008 02:27 AM
You should list the rest of the parts in your system.
I'm not into work today Rob, so maybe give me a shout after work and we'll get a look at it. (At the very least I can slave it into the test bench to verify that the card does or doesn't work).
3.0charlie April 21, 2008 04:07 AM
What's your PSU? You may be short in Watts.
sswilson April 21, 2008 06:11 AM
Heh.....
I think he's got that hooked up to a new 750W PC P&C :)
Couple of things that might be going on here.... first is that he thinks it is an original PCIe 1.0 (no "a"), second is that there might be issues with the via chipset.
rob123 April 21, 2008 06:45 AM
yes, i have a month old pc power and cooling 750 watt supply.
i am finding that ss wilson is probably right. either the via chipset or the 1.0 (no A0 pcie slot.
rats rats rats
one step forward and 2 back
will let you all know how the test goes
thx for replies
rob123
thatguy April 21, 2008 08:44 AM
rats rats rats
thx for replies
rob123
you found your own problem
werty316 April 21, 2008 08:49 AM
As far as I know the 8800GT has been known for having problems with boards using a VIA chipset so you'll have to contact your board manufacturer (ASRock) for a BIOS fix and if they don't have a solution contact Asus for a updated BIOS else you are sunk.
rob123 April 24, 2008 07:32 PM
thx to all for the replies.
it has been found that the culprit here is definitely the pcie slot. i mailed to asrock and they told me to go to the video card manufacturer who told me to go the the motherboard manufacturer.
instead of all the further fuss i obtained a gigabyte ep35-ds3r motherboard. not a real fan of passive cooling so i will hop over to another part of this forum to ask about cooling the chipset.
thx again
