-   -   660 Ti in SLI (http://www.hardwarecanucks.com/forum/video-cards/56835-660-ti-sli.html)
CHINQAZOID September 20, 2012 05:32 PM
660 Ti in SLI
I'm not sure if this is the right category to post this thread on but I have an Asus DirectCU II OC 660 Ti and I want to get another one of them and go SLI. But I don't know if my PSU will be able to handle them. I have the corsair ax650 psu.
Dzzope September 20, 2012 06:36 PM
Should be able to (depending on other components)
Ideally you would have a 750 watt but as long as your not getting full load on everything in your system (like in a stress test) then you should be just about ok..
Soultribunal September 21, 2012 07:20 AM
650 on the AX is more than enough for 660TI's.
Even if you had a HEX in there you would be fine.
-ST
mattlef September 21, 2012 07:42 AM
I'm going to do the same thing.
As long as your PSU is rated decently, you should be okay.
i'm going to run something similar soon on a Seasonic X-650, so you should be able to get away with it even under 100% load.
I've seen a 2011 setup, overclocked, with two of these cards only pull 513w... so its possible.
