Originally Posted by velias A lot of people feel nvidia does better in terms of multi GPU profiles, is that a fair assessment? |
I'd address that question in two ways. First and foremost, I believe there was a time when AMD's Crossfire profile development was behind NVIDIA's. It was that ~year around the 5000-series where things really weren't all that pretty and it did give AMD's drivers a bad name in certain circles. The HD 6000-series did feature drastically better compatibility of Crossfire within games but there were still some stumbling blocks. The HD 7000 series is another step in the right direction.
This isn't to say that NVIDIA was absolutely perfect because I distinctly remember SLI issues with Starcraft II and a number of other popular games after patches or initial releases.
In the past, we can't forget that NVIDIA poured an obscene amount of money into their TWIMTBP program and it paid dividends. AMD's Gaming Evolved program was around but not nearly as effective as it looks to be this coming year. Developer relations are a huge deal when it comes to optimizations as well and it seemed NVIDIA was significantly ahead in this regard.
Personally, I think many AMD driver issues stem from the fact that
their uninstaller needs reworking. It leaves far too many little gremlins from past installs running around the system, potentially screwing the pooch. Fro example, I have to run the driver-based uninstaller (no, the Device Manager shortcut won't cut it with AMD drivers) and then run BOTH Driver Cleaner and Driver Sweeper in Safe Mode after uninstalling an AMD graphics card. If I don't, the system will likely throw a fit when I either A) Install an NVIDIA GPU or B) Install a Crossfire setup. With the newest NVIDIA drivers, I can literally run the Device Manager uninstaller and be confident that SLI, single cards, AMD cards or Crossfire can be installed once the system is rebooted.
At the risk of sounding petty, the mere fact that we need to use secondary software tools to properly uninstall drivers simply boggles the mind. AMD and NVIDIA know exactly what's installed; why can't their uninstallers get ALL of it out of our systems? If that can happen, I can almost promise you that the vast majority of problems (other than missing / broken profiles) will be effectively fixed.
So are NVIDIA's multi drivers "better" than AMD's? These days, I'd say they're pretty even. What people seem to forget is that great strides have been made with the
APP Profiles. What AMD needs to work on is getting the word out whenever a new CAP file is released.
