Old April 19, 2008, 08:35 PM
Infiniti's Avatar
Default GPU Question...
Is using a different slot to put in my GPU(8800GTX) on the 680i mobo fine? Because I think there would be some clearance issues with my new WC gear and my WCed SB.
Old April 19, 2008, 09:27 PM
werty316's Avatar
Yeah using one of the other PCIe x16 slots is fine.
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
