Old September 7, 2012, 04:30 PM
Default Oopsy, I have disabled my graphics card :(!!!
My situation is that I got the x51 from dell in the mail 5 days ago, it was working fine hooked up via hdmi to my tv till I updated my drivers and accidently disabled my integrated graphics(Not my discrete gtx 555, & yes I know I'm an idiot)because I thought it had no purpose, but I guess in doing that it disabled the hdmi port where I was hooking up my tv via hdmi to use as my monitor??...See the problem now? Now I have a blank tv screen at all times no matter what so I cant boot into bios or safe mode or reinstall windows because I can't see what I'm doing even when booting. So maybe theres a way to hit a certain combination of buttons on boot blindly to fix it in bios or something?. So maybe you can go into bios or something and tell me exactly what button combination to push to enable or fix something? I don't know anymore, I just want to have fun with my new computer I had waited 4 weeks for!!!
& yes I know that I can get a DVI cable and use the spare monitor I have, but I went to a few stores around me and the cheapest dvi cable(or adapter) was 25$ So I would rather see if I can fix it some other way first before paying that for a cable I will only need for 5 minutes...
Cheers.
(Don't know if this is the right section to post this, if not please delete/move and tell me where to put it, sorry.)
Old September 7, 2012, 04:45 PM
stoanee's Avatar
No hdmi on vid card? On the Dell site it shows one.
heatware
Old September 7, 2012, 04:49 PM
what???
Old September 7, 2012, 04:55 PM
3.0charlie's Avatar
Where are you connecting this HDMI cable on the tower - next to the USB ports (I/O panel), or on the discrete GPU?
Hydro-Quebec is salivating...
Old September 7, 2012, 05:04 PM
I am connecting it to the hdmi slot on the back of the pc. I don't have it connected to the discrete gpu I think...I thought it was connected to the integrated, which I disabled!
Old September 7, 2012, 05:16 PM
Old September 7, 2012, 05:27 PM
BigPhatPaulie's Avatar
So use the discrete card? till you can enable the integrated?
FOR PONY..... that is alll
Old September 7, 2012, 05:41 PM
Yeah I acknowledged that earlier, I said I could use the two dvi ports which are powered by my discrete, but I wanted to explore the options & see if I could get the hdmi to work before I spend 25$ for a cable I will need for 1 day.
Old September 7, 2012, 06:15 PM
Why do you even have a discrete card if you're just using the integrated one anyways?
Old September 7, 2012, 06:16 PM
stoanee's Avatar
See what a hdmi to mini hdmi adaptor (on gpu) costs. I think you will have to get one unless you can borrow one. Can you be more specific on how you disabled the hdmi port?
heatware
Intel HD Graphics with Graphics Card MoUnit CPU's and Motherboards 4 August 6, 2011 03:54 PM
AMD Extends Graphics Performance Lead, Launches World's Fastest Graphics Card? Again! FiXT Press Releases & Tech News 2 March 8, 2011 03:32 PM
Crossfire being disabled chibi_man O/S's, Drivers & General Software 0 December 19, 2009 01:39 PM
registry disabled by admin MrFoxx O/S's, Drivers & General Software 7 July 8, 2009 06:32 AM
