Old September 7, 2012, 06:29 PM
JD JD is offline
Not the easiest, but if you open up the case and look for the battery on the motherboard, then remove it for 1-2 minutes, it should reset everything.
Of course, make sure you unplug the power cable before opening the case.
Old September 8, 2012, 04:24 AM
Dzzope's Avatar
Dell system that will void the warranty?
Forgive me if I missed it, is there a HDMI port on the discreet GPU?
Instead of buying a DVI lead why not borrow one off anyone with a computer?
Old September 8, 2012, 04:08 PM
JD JD is offline
How would that void the warranty? Dell doesn't let you open up your own desktop computer? That seems ludicrous.
Old September 8, 2012, 06:31 PM
Silent_Avenger's Avatar
Actually CanadaComputers will not let you open your pc unless you void the warranty if you had your pc repaired there. So I could see dell doing something like that as well.
Main System //// Dedicated Folding PC 1 //// Dedicated Folding PC 2 //// Laptop
Youtube Channel: http://www.youtube.com/DarkDivinityPC
I fold for a cure. Team 213366 and 54196.
Old September 8, 2012, 06:37 PM
Bond007's Avatar
I am quite confused about this thread.
A) are you currently getting any displays to work?
B) What connectors are on the graphics card and what connectors are off the motherboard (HDMI/DVI/etc)?
Old September 9, 2012, 05:27 AM
Hmm the instruction manual for the Dell computer has a nice warning for opening the case (although if there's no "void warranty" tape, no one will notice).
As Dzzope mentioned though, the easiest way out of this is to borrow a DVI to HDMI adaptor, DVI cable, DVI-to-VGA + VGA cable, etc from someone. Either that or bring the computer to your friend/workplace if you know they have the cable you need - that X51 doesn't look like a particularly large computer.
Intel HD Graphics with Graphics Card MoUnit CPU's and Motherboards 4 August 6, 2011 03:54 PM
AMD Extends Graphics Performance Lead, Launches World's Fastest Graphics Card? Again! FiXT Press Releases & Tech News 2 March 8, 2011 03:32 PM
Crossfire being disabled chibi_man O/S's, Drivers & General Software 0 December 19, 2009 01:39 PM
registry disabled by admin MrFoxx O/S's, Drivers & General Software 7 July 8, 2009 06:32 AM
