Old September 6, 2012, 05:15 PM
Coach's Avatar
Driver Cleaner is what I own. I would highly suggest you clean out the old AMD drivers and then reinstall the latest Nvidia drivers
Old September 7, 2012, 07:28 AM
Well, I also have the same problem with my gtx690, on gw2 at max, my fps is low, 40-65, but in most of my other games it's like between 100-400, depending on the game. And I was starting with a fresh windows install, so no previous driver there.
I'll continue to work on that too, and see if I can get any results.
Old September 7, 2012, 07:52 AM
Dzzope's Avatar
Is there an SLI profile for GW2? worth looking into if it even supports it yet..
Old September 7, 2012, 08:45 AM
Someone told me there was a patch for that, that, but I didn't found it on the web, I'll ask him later this weekend when I'll see him. But i would have thought that it would have perform better even with only one 680.
Old September 7, 2012, 07:21 PM
Originally Posted by JD View Post
The GTX690 is not really the right card for 1080p though...
Have you tried doing a driver wipe? Drive Sweeper does a pretty decent job. I'd check off both ATI and NVIDIA options, while running in safe mode. Then install the latest beta NVIDIA drivers.
Also check in the NVIDIA control panel that there's no v-sync stuff enabled. Maybe Adaptive V-Sync is on by default?
V-sync is off in the control panel and I have done a full driver wipe using driver sweeper. Though I did not wipe the Nvidia Drivers so perhaps I will do that and re download in safe mode. Ty. Will keep posted.
Old September 7, 2012, 07:22 PM
Thanks alot. Let me know your findings.
Old September 8, 2012, 06:34 AM
Trial Member
having exactly the same problem, got low fps in gw2 and cs:go crash (blackscreen, need 2 reboot,,)
well, i am waiting the new driver version. maybe gonna go out with the geforce650..
here is my spec:
-CPU: intel 3930K @ 4.5ghz -Super Thermal Grease ZM-STG2
-VIDEO CARD: Geforce EVGA 690GTX
-SOUNDS CARD: Asus Xonar Essence STX
-logitech G5
-Corsair K60
-headset :
SONY MDR-V700,
ATH-PRO700MK2
-16g Kingston HYPERX 1866mhz
-MB: Asus P9X79 DELUXE
-PSU: Corsair AX1200i
-CASE: Antec Twelve Hundred
-Heatsink: zalman CNPS12X
-SSD: OCZ 240GO REVODRIVE3 X2
-SCREEN: BENQ XL2420T
Old September 9, 2012, 09:18 AM
here is my spec:
-logitech G5
-Corsair K60
-headset :
SONY MDR-V700,
ATH-PRO700MK2
Yep. black screen and reboot. It's irritating. =/
  #19 (permalink)
Old September 9, 2012, 09:55 AM
Trial Member
Well. I have the same problem.
But mine is GTX670, and I encountered the same situation many times.
CS:GO is black screen and reboot;
Dirt: Showdown, BF3...when I play these games after 10mins, the FPS suddenly drop to maybe 20 or 30. And there's still nothing I can do about it.
Someone said that it might be caused by the driver version, especially for GTX6xx. But still cannot confirm that.
Help!
  #20 (permalink)
Old September 9, 2012, 10:23 AM
NyteOwl's Avatar
Oddl. I wonder if somehow related to the clocking anomalies that showed up in the 660 roundup results?
Obsolescence is just a lack of imagination.
GTX 560 Ti problems. adamdavidson Troubleshooting 8 April 4, 2011 11:21 AM
PS3 problems... Cptn Vortex Off Topic 10 June 22, 2010 09:02 AM
new pc problems... tzetsin Troubleshooting 12 May 17, 2008 08:17 AM
Help Please (2 problems) AnthraxAdrian Troubleshooting 20 April 27, 2008 11:34 AM
Big Problems Feff Troubleshooting 9 January 23, 2008 04:24 PM
