Old September 7, 2012, 01:08 AM
-Wolverine-'s Avatar
Originally Posted by ipaine View Post
Ok I have a quick question that I can not seem to find a proper response for on the interwebs.
I need to know what the power supply requirements are for a Asus ENGTX570 DirectCU II. I have only found on one review and would like to know if it is correct. The one review on legitreviews states that it needs a 550W PSU. Can anyone confirm or deny that?
I have a older machine here at work that they want to stick this card into, but it only has a 430W antec with 17A on the 12V. I doubt it is powerful enough and I just want to be sure.
Thanks
A suppose that is Antec Basiq series. So I'd recommend you to buy better quality PSU for that rig. And about the power that you'll need, you can buy any quality brand 500-550W PSU.
In my tests rig was:
Intel Core i7 2600k @4,5 GHz @1,35V
Intel DP67BG
2x 2GB DDR3 1600 CL7
1x 2TB HDD SATA3 WD Black
DVD-RW
Thermaltake Toughpower Grand 1050W 80+ Gold
And with Gigabyte GF GTX 570 SOC it pulled out
Idle: ~120 W
DiRT3: ~350 W
Furmark: ~385 W
Prime95 + Furmark: ~485 W
And those numbers are form the wall outlet so it really needed ~440-450 W under full load.
''Of all the things I've lost I miss my mind the most''
Mark Twain
Old September 7, 2012, 05:35 AM
elmorejohn46's Avatar
ypu will need a better power supply if you just have an older antec 430w it probally does'nt even have the two 6-pin PCIE plugs on it and just the 570 card will draw over 200watts and need at least 18a to 20amps on the 12v rail of the power supply just for the card.You need at least a good 550w powersupply with around 45amps on the 12v rail.
Intel-i7-3820+Corsair H-100+Gigabyte X79-UD5+16g G.Skill 1666DDR3+256g Crucial-SSD+1-3TB Seagate+2-1TB-Samsung+1-640g- WesternDigtal+SLI-ASUS DIRECT CU II GTX-670+LG-12x Blurner+Logtech G9x-mouse+G-110-keyboard+Driving Force GT Wheel+Pioneer VSX-1020K+Polk Audio Speakers+LG-50"Plasma PM6700+Antec-P280+XFX 850w PRO Semi-Modular
4870x2 power requirements Jonwall Video Cards 15 January 12, 2010 08:25 PM
XFX power supply requirements... BrokenHalo83 Video Cards 2 April 26, 2009 09:21 PM
does power supply met vid card requirements Maxtor Power Supplies 3 April 2, 2009 04:09 PM
Power Supply Requirements enaberif Power Supplies 9 August 1, 2007 02:22 PM
Power Requirements enaberif Power Supplies 6 July 10, 2007 06:20 AM
