Old September 3, 2012, 08:52 AM
Default GTX 670 HDMI and DVI doesnt seem to work?!
Hi, i made my own Gaming Pc 1 month ago, and when i first turned on the computer the screen kept being black, so i shifted out cables and tried the VGA converter and it worked, but since then i've been playing at 1680x1050 and thats not near as much as i could get out of this card...
Do you guys have any solution to my problem? I've already checked other forums and nothing seem to work..
Things that i've tried
Turn of integrated graphics
Bootup with either HDMI or DVI
Nvidia Control panel settings (It did not show the other display cables only VGA)
And the cables work (tested)
Sorry for my bad english, hope you understand :)
Old September 3, 2012, 09:19 AM
Your not telling us what screen size your monitor is because vga, dvi, and hdmi can all do higher than what your getting.
Old September 3, 2012, 11:02 AM
Oh sorry its a ASUS 24 inch 1080p :)
Old September 3, 2012, 11:38 AM
Select PCI-E for primary graphics in BIOS.
Old September 3, 2012, 12:44 PM
Okay so i think i found it
"PCIE/PCI is selected to use as primary boot device"
I dont have the choice of only one of them so its either PCIE/PCI or PCI/PCIE and ive tried both..
It didnt work though thanks for fast reply :)
Old September 4, 2012, 12:10 AM
GT7R's Avatar
Maybe the monitor settings are wrong that it detects only the VGA? Try messing with it's settings, mainly the source button.
Old September 4, 2012, 01:56 AM
-Wolverine-'s Avatar
As GT7R said, it's most probably monitor setup that is wrong. Either set and use automatic video input selection or set up video input manually to correct type.
I've had same problem with Dell 2408WFP and GF 660Ti.
''Of all the things I've lost I miss my mind the most''
Mark Twain
Old September 4, 2012, 05:37 AM
^I dont seem to have that choice on my monitor... but it does detect when i attach the DVI or any other cable
Old September 4, 2012, 08:58 PM
elmorejohn46's Avatar
If your monitor excepts HDMI then I would use that or the DVI and your bios should be set at PCIE/PCI.Plus make sure onboard graphics are disable. Make sure you have uninstall all old video drivers and then install the newest nvida drivers 301.42.Make sure when you install the drivers to hit custom and check the to perfrom clean install.after it is rebooted it should show up as 1920 x 1080 on a 24" asus monitor.If not go to the nvidia control panel and set it manually.
Intel-i7-3820+Corsair H-100+Gigabyte X79-UD5+16g G.Skill 1666DDR3+256g Crucial-SSD+1-3TB Seagate+2-1TB-Samsung+1-640g- WesternDigtal+SLI-ASUS DIRECT CU II GTX-670+LG-12x Blurner+Logtech G9x-mouse+G-110-keyboard+Driving Force GT Wheel+Pioneer VSX-1020K+Polk Audio Speakers+LG-50"Plasma PM6700+Antec-P280+XFX 850w PRO Semi-Modular
Old September 7, 2012, 09:58 AM
I did all you said, but it still doesnt seem to work...
Tags
dvi , nvidia gtx 670 , problem
My first build doesnt boot :S Atmax Troubleshooting 13 February 15, 2011 07:27 AM
New computer doesnt boot, need help! Ironmonk Troubleshooting 5 October 21, 2010 04:06 AM
G Skill PC2-8000 4GB Kit, doesnt work at 1000Mhz.. =/ Yamcha Troubleshooting 2 April 6, 2009 03:23 PM
OMG such bad luck. Kaze screen doesnt turn on :( arekieh Troubleshooting 7 November 25, 2008 07:09 PM
my tread doesnt update? thatguy Off Topic 4 April 20, 2008 06:33 PM
