Old August 27, 2012, 11:42 PM
hi everyone
thank you all again,for every help i received from you.
i had a look for some graphic card,from (asus,xfx,sapphire),nearly all the websites for those graphic card,require to Flash the BIOS,to be able to use the graphic card.
the desktop i have and the motherboard (Acer aspire M7720),i went to Acer webiste,and found out my BIOS is old,and they have newest version of BIOS.
honestly i am so afraid to update the BIOS,because if i done something wrong i will ruin the motherboard,you know that i think.
please i am sending you some links for the graphic card i found:
http://www.amazon.co.uk/Sapphire-111...6135816&sr=8-1
Asus ATI Radeon HD 6870 DirectCu Graphics Card (1GB, PCI-E 2, 915MHz Factory Overclocked Edition Operation): Amazon.co.uk: Computers & Accessories
XFX Radeon HD6870 Graphics Card PCI-e 1 GB GDDR5 Memory Dual DVI HDMI Dual DP 1 GPU: Amazon.co.uk: Computers & Accessories
please which one do you think is better,i know all models ati 6870,but please i need quiet and good one in term of playing games and watching movies.
i hope to hear from you very soon.
have a very lovely days
my kindest regards
habs2habs
Old August 29, 2012, 08:07 PM
XFX
Old August 29, 2012, 08:40 PM
BlueByte's Avatar
I have heard bad stories about XFX warranty, and have been afraid to touch them with a 10' pole.... I personally have had both Asus and Sapphire and have had to warranty to both companies, if I were to buy one off those sites save the 20 and go for the Sapphire. It looks like it would vent out of the case a bit better then the Asus as well. my 2 cents....
Tags
graphic card
i need an graphic card for x4 slot jksynapse Video Cards 6 February 18, 2012 04:27 PM
Will another graphic card fit? biagio1661 CPU's and Motherboards 3 January 15, 2012 02:21 PM
graphic card for PCI-X 64-bit/133 MHz slot jksynapse Video Cards 2 January 27, 2009 07:04 AM
