| Dzzope | August 22, 2012 06:26 AM | Quote:
Originally Posted by vishal
(Post 650318)
I play games like crysis 2 bf3 NSF run at 1600 * 900 at max settings........ Will it make my computer exceed 450 w ??? | The issue isn't "If your computer will draw 450W".. it's the stability of the PSU and as mentioned above the amperage is an issue too (I had to upgrade an older (but good) 550w PSU as it had 3 rails and none had high enough amps to drive my GPU.
Apart from the danger to your parts if (When) the PSU fails.. The amperage (on second look, well spotted Bond) won't be enough for a 560. |
