  #31 (permalink)
Old August 16, 2012, 11:59 AM
great_big_abyss's Avatar
For those that are doubting Sky's results, read The Tech Report GTX 660Ti Review. While they use a different methodology (they go 'Inside the Second'), their results are quite similar to those results found here.
Anyways, their results are such that the 7950 actually beats the 660Ti in most benchmarks, but not by much. They ARE using an OC'd version of the 7950, as well as a 7950 with the new Boost BIOS.
The 7870 ALSO edges out the stock GTX660Ti in a few benchmarks, but once again, they're using an upclocked (1100MHZ) MSI 7870 Hawk. They also test an upclocked Zotac 660Ti AMP! that subsequently beats out the 7870 in every test, but is still slower than the 7950's they have.
Whatever. The point is, that when it comes to the 7950 vs 660Ti, the two cards are quite evenly matched, and honestly, I believe it just comes down to brand preference. The 7850 IS a little slower, but it's also typically $50 cheaper, so that's to be expected.
Rule of thumb: If you're playing at 1080P or less, go with a GTX660Ti, or if you want to save a bit of money, a 7870. If you can afford a little more money, go with a 7950.
If you're playing at greater than 1080P (27" or 30" single display) go for a GTX670 (or to save a bit of money, a 7950).
For Eyefinity, either a GTX680 or a 7970.
Done! Now, let all the arguing stop!
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; Sapphire HD5870; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; ASUS GTX650Ti Boost; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
  #32 (permalink)
Old August 16, 2012, 12:05 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
The people crying "BIAS!!!" will likely be quiet.....until they see something else they don't like....
  #33 (permalink)
Old August 16, 2012, 12:20 PM
sswilson's Avatar
Bias??? Isn't that what we're supposed to do in order to change the state of a discrete transitor?
  #34 (permalink)
Old August 16, 2012, 12:24 PM
Originally Posted by great_big_abyss View Post
For those that are doubting Sky's results, read The Tech Report GTX660 Ti Review.....
Can you fix the link? The Tech Report GTX660 Ti Review
  #35 (permalink)
Old August 16, 2012, 12:44 PM
Bullshit? So you're saying toms and HT4U is biased and you aint? Let's see..
I'm just gonna ignore Anandtech as they are known to be biased.
Legit reviews benched 3 overclocked cards? And from what I can see, they still lost some benchmarks to the 7870?
Did you even look at their benchmarks? Out of the 4 games the overclocked 660 Ti's lost 3? Are you so biased that you see green wins even when they lose?
Care to point out what you see in the techreport's review that backs you up? From what I can tell, the 7950 is streets ahead in everything except BF3, and the 7870 Hawk is close enough to the 660 Ti for it to be a draw.
TPU - the 7950 is faster at 1080p. Once again I have to ask how this backs you up? Like I said you are the ONLY site I've seen that has a victory for the 660Ti at 1080p.
Yes, it's clear who is biased.
  #36 (permalink)
Old August 16, 2012, 12:53 PM
Im not shure if its a bias thing per say .... I think abyss summed it up prettymuch in his post there. The reality is right now between the 2 companies there is a VERY large grey section in the mid stream of cards that quite honestly probly at this point in time its a wash.
It's ultimately gonna not change anything cause those loyal to x company will still buy there company's card over the others cause of there factual or unfactual beliefs in such company.
In the end as much as this now confuses some of us the consumer .... those whom can wade through it all but will see its super beneficial to us.
I for one will find it interesting if Sky or some other reviewer out there will do a head 2 head of 7870's vs 660's in crossfire/sli preformance ..
  #37 (permalink)
Old August 16, 2012, 01:02 PM
Overclocking.ca's Avatar
Tom's did a SLI & Crossfire comparison
http://www.tomshardware.com/reviews/...w,3279-10.html
  #38 (permalink)
Old August 16, 2012, 01:05 PM
Master_Shake_'s Avatar
AMD has a full line up cards despite the 7990 being absent and at this point who cares...
Nvidia has a lineup including a dual gpu but no bottom end 650....
i say enough of this generation!!!!
The weathers getting cooler and its time for pants again so i say,
BRING ON THE 8000 and 700 SERIES ALREADY!!!!
  #39 (permalink)
Old August 16, 2012, 01:13 PM
SKYMTL's Avatar
Indeed, you are completely biased against NVIDIA. I have a good laugh whenever I hear someone shouting "BIAS!" when a website doesn't play lip service to their erroneous expectations.
I see you picking and choosing but not looking at the larger picture. Clearly, your bias is not allowing you to look past the AMD-colored shades across your eyes.
There is NO DOUBT that at 2560x1600 the GTX 660 Ti and HD 7870 are in a statistical dead heat. Neither card is geared towards that market though since neither actually provides playable performance in the most scenarios anyways.
BUT, if you average out performance across ALL detail settings, the GTX 660 Ti is ahead by a substantial margin, particularly at 1080P. Every one of these points was brought up in our review. It seems you are looking at charts without READING and more importantly UNDERSTANDING. As such, I suggest you re-READ the reviews I linked to and even the ones you have so graciously linked....since they all come to the same conclusion as we did: in DX11 applications at 1080P or 1200P, the GTX 660 Ti is by far a better performer.
  #40 (permalink)
Old August 16, 2012, 01:15 PM
At this rate, AMD will have paper launched the 8970 before Nvidia has completed their entire lineup!
NVIDIA GTX 680 2GB Review Comment Thread SKYMTL Video Cards 148 April 3, 2012 05:56 PM
Comment Thread for AMD HD 6990 Review SKYMTL Video Cards 73 March 22, 2011 06:21 PM
BFG GTX 285 OCX Review Comment Thread SKYMTL Video Cards 8 January 21, 2009 01:55 PM
BFG GTX 260 Review Comment Thread SKYMTL Video Cards 33 November 15, 2008 10:26 PM
BFG GTX 280 OCX Review Comment Thread SKYMTL Video Cards 15 August 19, 2008 08:07 PM
