Keep getting mixed responses - $300 7950 or $400 GTX 670 for gaming at 2560 X 1440. Keep getting mixed messages. So I came to the least biased place I know. Which card should I pick up to game at 1440p? The MSI Twin Froz 7950 3GB or EVGA GTX 670 FTW 2GB. |
670 its noticeably faster than the 7950 bar none |
The stock 670 outperforms the stock 7950 by about 14%. I'd think you'd see a similar difference between the OC'd cards mentioned. http://www.hardwarecanucks.com/forum...review-11.html |
I'd go with the 670, even at that resolution the extra video memory isn't going to make a large enough impact to offset the superior power the 670 has over the 7950 |
If u can handle the added cost I would go for the 670. If money is tight the the 7950 is a good alternative (at least until the 660 comes out). |
Nvidia drivers>AMD |
Actually, for $100 more, I wouldn't get that GTX 670. Either get a stock GTX 670 or wait until the "new" HD 7950 is available which should net ~10% more performance for (supposedly) the same price. If that HD 7950 sticks to the current $309 price, it will be a killer deal. |
Is there any point in posting after SKY? Well I will anyway... I run 2560X1440 with a single Gigabyte GTX 670 Windforce and I gotta say I am still in need for a little more processing power. As far as the frame buffer the highest I have seen it used was ~1.6GB. My only advice to the OP would be to buy the most powerful card you can. |
Back to the question at hand, we're talking about 25% price difference from the 7950 to the 670. I mean it's $100 for somewhat similar performance. You could get a very nice SSD for that price! In fact, do that. If you don't already have one. Pick up a 128GB SSD for the difference and perk up your system a whole bunch. |
Go amd and mine bitcoins to offset cost!! :D |
| All times are GMT -7. The time now is 04:10 AM. |
