<~----> Keep getting mixed responses - $300 7950 or $400 GTX 670 for gaming at 2560 X 1440. - Page 3 - Hardware Canucks
  #21 (permalink)
Old August 18, 2012, 07:57 PM
great_big_abyss's Avatar
Originally Posted by Silvgearx View Post
Half of the time. LMK if all your "new ironed out" AMD drivers work out of the box.
...but they do work 'out of the box'...Each update gets progressively better.
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; ASUS GTX650Ti Boost; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; Sapphire HD5870; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
  #22 (permalink)
Old August 19, 2012, 03:17 AM
Supergrover's Avatar
While I run a xfire setup I have to disagree, I have had quite a few driver updates bork my multicard setup in some games, but again that can be atributed to a multicard setup.
Dont get me wrong I am not saying "AMD driver suck" but they can get temperamental depending on your setup. Single cards dont seam to have near the issues though.
R.I.P.
  #23 (permalink)
Old August 19, 2012, 05:38 AM
Originally Posted by yohohobo View Post
You might consider throwing in a gtx 660 Ti into the mix, now that it's out.
No.. Not got the memory bandwidth for the high res stuff..
Single card pick for me at the mo would be 7970.. it beats the 670 at higher res.. is about the same price..
Though if your really not wanting AMD the 670 should be fine.
Intel 6 Series Chipset Debacle: Manufacturer and Retailer Responses FiXT Press Releases & Tech News 29 February 1, 2011 04:48 AM
GTX 480 SLi Benches 2560 x 1440 rjbarker Overclocking, Tweaking and Benchmarking 0 November 20, 2010 05:08 PM
U2711 2560 x 1440 Text Unreadable Adjustemnts Made. rjbarker Display Units 10 November 16, 2010 07:06 PM
