Old August 15, 2012, 08:43 AM
Originally Posted by great_big_abyss View Post
Back to the question at hand, we're talking about 25% price difference from the 7950 to the 670. I mean it's $100 for somewhat similar performance. You could get a very nice SSD for that price!
In fact, do that. If you don't already have one. Pick up a 128GB SSD for the difference and perk up your system a whole bunch.
I 2nd this
Asus Rampage IV Extreme | Intel i7 3820 | Crucial 4x4Gb | OCZ Vertex 3 MaxIOPS 240GB | WD Velociraptor 1TB | WD Black 1 TB | AMD 7950 Trifire | Win7 Pro 64 | XSPC Raystorm | 2 x Alphacool XT45 360 | EK - FC7950 + Triple Bridge| 2x Liang DDC 3.25 | Koolance RP401X2 | Case Labs M8 |
Old August 15, 2012, 09:32 AM
LOL mine bitcoins to offset cost, great concept, takes a heck of alot of mining to get anywhere these days :P
Personally I hate Nvidia, so I will not vouch for them, driver wise as of late they have both had thier issues, games wise, depends on game will tell which is more powerfull. A stock 7950 vs stock 670 at the low to mid resolutions i.e up to 1920x1200 the 670 is the better card from performance in most games. High resolution i.e 2560x1440 and above(multi-monitor) the 7950 is easily as good if not better as it has more ram and such to work with.
At least the reading I have done says this, below said reso, tilts in favor of Nvidia Keplers, above said reso and multi-mon, easily tilts in AMD favor. But you are saving $100, the radeon is easily overclocked and gains a good chunk of performance from doing so, and adding an SSD to the mix and= the same price to a touch more, the Radeon will give more value/$ :)
Old August 15, 2012, 02:13 PM
GT7R's Avatar
Why not get a 7970?
Old August 15, 2012, 03:25 PM
dandelioneater's Avatar
at 300 dollars for a 7950, you are getting better bang for the buck. 670 is considerably better, but still 100 bucks more. my 2cents...
Old August 15, 2012, 05:32 PM
Silvgearx's Avatar
For single card setup ATI drivers are not that bad, just don't expect to update to the lastest driver and expect it to work. It usually takes a few more updates for ati to iron out there problems.
Old August 15, 2012, 07:51 PM
great_big_abyss's Avatar
Ya, see I don't get this. Driver updates ARE AMD ironing out their problems...
Truth is, drivers from both camps work admirably well. Especially if you're using a single card with a single display. I've never run into any problems, and anyone who says otherwise is just quoting problems from a decade ago when driver issues were acually real.
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; Sapphire HD5870; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; ASUS GTX650Ti Boost; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
Old August 16, 2012, 01:28 AM
Originally Posted by GT7R View Post
Why not get a 7970?
7970 will easily beat a 670 at the higher resolutions and can be had at the same if not cheaper price.
An Asus DCII 7970 is $429 ($409 after MIR) thats $10 either more or less expensive than the 670 (both are on special at NCIX this week)
There are other options with larger MIR's or less known manufacturers with no MIR but just as cheap or cheaper.
At your res I would go either for what sky said (the updated bios 7950) or a 7970... 670 is slightly over-priced now.
(at launch the 670 was much better bang for buck than either of these but Nvidia seem to be making a mistake with their pricing now rather than AMD)
Old August 16, 2012, 11:21 AM
You might consider throwing in a gtx 660 Ti into the mix, now that it's out.
  #19 (permalink)
Old August 18, 2012, 05:21 PM
Silvgearx's Avatar
Half of the time. LMK if all your "new ironed out" AMD drivers work out of the box.
  #20 (permalink)
Old August 18, 2012, 06:34 PM
I am changing my mind on my previous decision. Given your resolution I would go for a 7950 (wait for an updated bios one if you can). At your resolution the added cost of a 670 wouldn't net you much gain. Hunt around for a good 7970 deal if you can.
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Intel 6 Series Chipset Debacle: Manufacturer and Retailer Responses FiXT Press Releases & Tech News 29 February 1, 2011 04:48 AM
GTX 480 SLi Benches 2560 x 1440 rjbarker Overclocking, Tweaking and Benchmarking 0 November 20, 2010 05:08 PM
U2711 2560 x 1440 Text Unreadable Adjustemnts Made. rjbarker Display Units 10 November 16, 2010 07:06 PM
