Ideally you will have more intake fans, than exhaust ( 2 intake, 1 exhaust) for positive air-pressure, or the same number of fans for both is fine also.
The temps are somewhat high, but nothing to be concerned about as HTPC's often tend to run a little warmer. May I ask what temperature monitoring program you are using?
Also, make sure to tidy up the wiring. It is common when there are cooling problems, that they will surface when it is warmer out, you are probably better off adding fans, or try moving it to another location.
