<~----> Type of card to pick>? - Hardware Canucks
Old August 2, 2012, 11:26 AM
Default Type of card to pick>?
What's the most reliable, best videocard to buy? (type)
OC,
TOP,
DC II,
SC,
original..
Any comments on differences / options would be appreciated,
thanks!
Also,
Asus,
EVGA,
MSI,
etc..
Old August 2, 2012, 01:16 PM
NyteOwl's Avatar
Open ended questions are virually impossible to answer. WHy?
Do you want AMD or nVidia or Intel? (gpu manufacturer preference)
Do you have a brand preference?
Do you have a budget limit?
Do you want to just surf, or do business applciations, game, program, graphics, design, CAD, etc
Do you want maximum compute capability on the GPU?
DO you want maximum open source code available, or maximum capability under open source?
What are your priorities (overclock, power efficiency, cooling, multimonitor, inferfaces)?
Obsolescence is just a lack of imagination.
Old August 2, 2012, 09:26 PM
I'm just looking for the most reliable graphics card.
i wasn't sure if having an OC / SC was risky? Also don't know the differences between TOP AND OC.
Was just looking for a bit of guidance.
Old August 3, 2012, 12:46 AM
Adzsask's Avatar
More details please...
Old August 3, 2012, 12:54 AM
The difference is like having a car with GT or Sport.. these aren't types of cards they are just slightly higher grade of the same models OR!! just marketing.. depending on which one etc..
Type of card would be a PCI - PCI express - AGP
Then you have the chip manufacturers... AMD or Nvidia (for the main part at least)
Then you have models of chips.. GTX 690 - GTX680 etc or HD 7970 - HD 7950 etc
Then board partners..Asus, Evga, gigabyte etc
THEN you have the oc, top dcii, etc etc etc
Basically start at the top and work your way down...
(though the very first one can be skipped pretty much 99.999999999% of the time these days)
price range and the intended use will decide if you go amd - nvidia and then which model of chip.. once you have that narrowed down you can get into the gritty of which board partner and specific card you want to buy..
Old August 6, 2012, 12:03 AM
Much like vehicles, it often comes down to name-brand preference, I have had good luck with Asus and their Direct CU cards. They have been robust, and the customer service was pretty good when I had to RMA. Try to figure out the size of power supply you have, or will need to upgrade to, to accommodate the GPU as well. What is your budget?
How much room do you have in your case ( to fit both the GPU, and the necessary number of PCI expansion slots)?
What are your main requirements of this GPU, such as GPU-compute?
Find out what type of ram a old pc has Blu RAM 13 March 31, 2011 08:25 AM
Cartoon type software? no_pulse O/S's, Drivers & General Software 2 January 6, 2011 05:58 PM
What graphics card do I pick for my HTPC Blu Video Cards 7 December 30, 2010 11:12 PM
New type of life found ipaine Off Topic 29 December 6, 2010 04:07 PM
speaker type and placement bissa Off Topic 41 October 21, 2009 10:38 AM
