Old July 29, 2012, 06:44 PM
Overclocking.ca's Avatar
Default 560 Ti SLI vs 670
Currently right now I have two 560 Ti's and I was wondering if I should sell them and get a 670? Maybe later on get another 670 later on down the road.
I also want to water cool and for the specific cards that I have I can't find a full cover water block because they are non reference cards.
I am using a resolution of 1920 x 1080.
Thanks
Old July 29, 2012, 07:12 PM
Pabz0r545's Avatar
Yes I vote gtx 670. Less power consumption less heat more performance!
hey there is a guy I know selling a gtx 670 on the forum right now!
Old July 29, 2012, 07:16 PM
Unfortunately I can't buy it now as I don't have the funds yet. I am sure I could probably only get $150-$175 for each of my cards.
Old July 29, 2012, 07:58 PM
Same performance... if you want the cooler running sell your 560's to cover most of the cost.. but at 1080 1 670 is PLENTY
From the leaked info so far the 660ti will be very close to the 670... might be worth it to sell at $150+ each for a $300 replacement.. time and tests will tell.
Old July 29, 2012, 09:35 PM
sswilson's Avatar
Yeah, when I was looking into the 680 I'm currently running I also attempted to estimate the relative performance of both the 680 and the 670 to the pair of sli'd 560ti (standard) cards. What it looked like to me was a gain with the 680, and pretty close to parity with the 670 as far as performance @ 1900 X 1200, but power / heat would be drastically reduced.
Old July 30, 2012, 12:44 AM
and available vram.. I was running 99% used video memory in a few games with my old 560ti.
Old July 30, 2012, 06:54 AM
Pabz0r545's Avatar
It will be hard to get more then $150 for them. I've seen 570's sell for $170-160 on kijiji. And those 560ti's are going to be a lot less desireable once the 660 or 660ti drops. If you are going to be doing that I would do it sooner then later.
Old August 6, 2012, 10:16 AM
Kinda off topic but, 570 vs 660... i know its now out yet, but which do you think would be a better buy?
Old August 6, 2012, 01:37 PM
Really should just start your own thread..
But IMO it's not worth the cost for the performance increase.. unless you get a really good price for your 570
A 560ti would just be worth it.. (IMO)
Of course it depends on what they retail for and how good they are (there have been some leaked benches already)
Old August 10, 2012, 01:32 PM
elmorejohn46's Avatar
You probally want get but around $130 to $140 for each .I sold my GTX-470 and got $135 for each but the GTX-670 was well worth it it was faster in most games and it was whisper quiet and uses less power,plus the 2gigs of video ram helped out when useing high FSAA.
Intel-i7-3820+Corsair H-100+Gigabyte X79-UD5+16g G.Skill 1666DDR3+256g Crucial-SSD+1-3TB Seagate+2-1TB-Samsung+1-640g- WesternDigtal+SLI-ASUS DIRECT CU II GTX-670+LG-12x Blurner+Logtech G9x-mouse+G-110-keyboard+Driving Force GT Wheel+Pioneer VSX-1020K+Polk Audio Speakers+LG-50"Plasma PM6700+Antec-P280+XFX 850w PRO Semi-Modular
