  #21 (permalink)
Old July 26, 2012, 08:39 PM
Ok so I just ordered 3 30" Dell Monitors online, I've been looking around online and found that the 7970 6GB edition is coming out? I'm replacing my 1080p monitors with Dell 30" monitors would a 7970 6GB edition be better than perhaps a 7990 (if they are coming out)? Doesn't the resolution performance on games depend on the video ram a bit? Since when did AMD update their drivers?
  #22 (permalink)
Old July 26, 2012, 11:33 PM
elmorejohn46's Avatar
If you are going to run three 30" monitors then you should go with two 7970 6gig to run at top resolution.I went with a ASUS GTX-670 DirectCU II because it is quiet and uses less power.But if you are going to run three 30'" monitors you need all te ram you can get.Amazon is a better place to buy from because they give you 30 days and they don't charge you restocking fee.
Intel-i7-3820+Corsair H-100+Gigabyte X79-UD5+16g G.Skill 1666DDR3+256g Crucial-SSD+1-3TB Seagate+2-1TB-Samsung+1-640g- WesternDigtal+SLI-ASUS DIRECT CU II GTX-670+LG-12x Blurner+Logtech G9x-mouse+G-110-keyboard+Driving Force GT Wheel+Pioneer VSX-1020K+Polk Audio Speakers+LG-50"Plasma PM6700+Antec-P280+XFX 850w PRO Semi-Modular
  #23 (permalink)
Old July 27, 2012, 03:52 AM
Dzzope's Avatar
that res.. you want about 4 gig on the card.. 2 -3 cards.. 7970's or 680's..
  #24 (permalink)
Old July 28, 2012, 07:59 PM
Why didn't newegg give a FULL refund, aren't they supposed to be good about that? Did they give you store credit or something? If not I'd raise hell.
i7 2700k - 7950 3GB crossfire - 4GB 1866 CL8 - 1600p
  #25 (permalink)
Old July 30, 2012, 09:15 AM
Smile Newegg...
Yeah well they are kinda pathetic when it comes to that sort of thing. I'm not sure if I'll shop from Newegg again. Amazon is much nicer about this kind of thing. Although Newegg is cheaper than Amazon for computer components. So I'm not sure what to think.
7970 or 7950? musicman Video Cards 9 February 26, 2012 09:44 AM
Amd HD 7970 James Bond 007 Video Cards 1 January 22, 2012 01:51 AM
7970 clshades Video Cards 4 January 17, 2012 11:27 AM
Should I get 7970 ? XFallen Video Cards 14 December 27, 2011 07:41 PM
