Old July 15, 2012, 11:02 AM
cozmosland's Avatar
Default What should i upgrade. gpu or cpu
Just wondering which i should upgrade first.
currently have an x2 550 that doesnt unlock to quad running at 3.8,
and running a 5770 oc'd to 1.01ghz core and 1450 memory.
i was temped to just get another cheap 5770 and cf but want to avoid driver issues and game incompatibility and also kinda like the 6950.
also thinking of upgrading to an x6 1100 or similar unlocked.
just wondering which would be better to do first, want to avoid bottlenecks.
also please dont suggest switching to intel.
thanks!
-Will
Old July 15, 2012, 11:43 AM
headsh0t's Avatar
Upgrade your CPU first otherwise you'll be bottlenecked if you get a new GPU.
Old July 15, 2012, 12:55 PM
What resolution are you running? A Phenom II at 3.8GHz is still pretty good, at least for most games. Having said that, I wouldn't shoot any higher than an HD6950/GTX 560 Ti, and I would definitely stay away from Crossfire/SLI.
Old July 15, 2012, 12:59 PM
supaflyx3's Avatar
Upgrade CPU first, you'll notice a large bottleneck if you get a new GPU first.
Old July 15, 2012, 01:08 PM
NSdeadly1's Avatar
What games do you play? I'm running 2 6950's in crossfire and have had ZERO issues with any modern games. That said, i'd go with the cpu first then gpu at a later date.
Old July 15, 2012, 01:31 PM
cozmosland's Avatar
I usually game at 1920/1080 unless it can handle it then go to 720.
i play alot of everything. skyrim dirt. anything new i get and play through.
be nice if my x2 could unlock :(
Old July 15, 2012, 02:17 PM
Ravenor's Avatar
I would say upgrade CPU first. Then grab a 7870or 7950 later.....you can handle any game at that point. Plus AMD has announced price drop across the board on the 7000 series card that takes affect Monday.
Old July 15, 2012, 04:12 PM
If you're only playing games, video card.
Old July 15, 2012, 04:17 PM
cozmosland's Avatar
thanks.
ok i know i started this in the video card area because i didnt know where to put it. i only have an am3 board. not am3+, which is the best bang for buck am3 cpu that is a 6 core.
thanks!
This may sound redundant but double check your motherboard first and see if it can even run X6. The 1100T is pretty rare these days and probably have better luck finding a 1055T which I read is a pretty good OC CPU.
Help me upgrade Sleal CPU's and Motherboards 16 April 21, 2011 06:01 PM
Upgrade i7 920 to i7 970? JD CPU's and Motherboards 18 March 22, 2011 06:31 PM
Looking for an upgrade for i3-530 Cowboy CPU's and Motherboards 5 February 27, 2011 12:29 PM
VGA upgrade from GTX 260 first, or CPU+mobo upgrade first? panzerfan Video Cards 9 April 6, 2010 08:25 PM
$500 upgrade JD New Builds 11 July 8, 2009 07:25 PM
