<~----> CFX/Eyefinity question? - Hardware Canucks
Old July 12, 2012, 11:24 AM
Default CFX/Eyefinity question?
Hey,
Question i'm looking to run a 3 monitor setup either Nvidia Surround or AMD eyefinity this post has to do with Eyefinity though.
My question is: if i'm running 2 cards in CFX and the game doesn't support CFX will i loose Eyefinity support as well?
Thanks
Old July 12, 2012, 11:33 AM
Arinoth's Avatar
It depends on the game really, but it won't break the actual 3 monitor desktop/stretch you have going on.
What will typically happens is it'll launch in 1 monitor, sometimes based on what your default primary/main monitor is, other times the far left or right.
Old July 12, 2012, 11:54 AM
Hey,
So if i'm playing game X and game X doesn't support CFX it will default to 1 monitor.
One last question, i know with nvidia srround, when you have cards in SLI 2 monitors hookup to 1st GPU and 1 monitor to GPU 2, is it the same with eyefinity? If it's not then i'm assuming when CFX isn't supportd it could run them off i GPU and then you FPS would drop threw the floor lol
Old July 21, 2012, 06:13 PM
With Crossfire, all monitors need to be plugged into the first video card. NONE of the outputs on the second GPU work while in Crossfire mode. (With SLI, the outputs on both GPUs work.)
If a game doesn't support Crossfire it should still run in eyefinity mode as eyefinity is not crossfire dependant. Most games that won't run crossfire are likely gonna have issues with eyefinity however. Although I'm sure there are some out there that will manage it.
We are shaped by fate, just as we shape it.
Question on surround/eyefinity Beastylemon Display Units 7 September 30, 2011 11:35 AM
Eyefinity question RJMik Video Cards 1 January 10, 2011 12:38 AM
eyefinity question megadave85 Display Units 5 July 29, 2010 06:20 PM
eyefinity question rogue woopa Display Units 10 July 23, 2010 05:25 PM
Eyefinity Question... xXxRithxXx Video Cards 2 March 5, 2010 03:38 PM
