Old July 12, 2012, 09:57 AM
MARSTG's Avatar
Exclamation SLI combinations
can I do SLI with an identical chip on PCI express and simple PCI port? or on 2 simple PCI ports?
Old July 12, 2012, 10:01 AM
no..? You can't use PCI ports .. Do they even make video cards that use PCI slots anymore?
but I'm not sure what you mean by 'simple'
Old July 12, 2012, 10:12 AM
Arinoth's Avatar
They make the odd PCI card, however no higher end card is. I don't believe a PCI-E card will properly fit/sit in a PCI slot. I wouldn't be surprised if the card or the slot would get damaged.
As long as it's the same card and architecture, aka the 560 Ti cannot sli with the regular 560, they can sli.
Here I am: here I remain
Old July 12, 2012, 10:21 AM
MARSTG's Avatar
gt430 and gt520 among others. Ok, I am not dumb, but I have a gt430 on pci express and there are models on simple pci port. My onboard chipset is nForce 3600
Old July 12, 2012, 10:31 AM
Dzzope's Avatar
Very odd question which I've never seen asked before... I really doubt it but would be interested to see if it was possible (not that I would advise ever doing it)
Old July 12, 2012, 11:10 AM
MARSTG's Avatar
I asked here as I haven't found the answer anywhere. I guess nobody cared to try?
Case Colour Combinations for HAF 932 bkh2 Cases 27 December 1, 2009 08:02 PM
8800gts sli combinations Babrbarossa Video Cards 3 February 12, 2007 03:26 PM
