Old July 11, 2012, 11:24 AM
Default Should I upgrade?
Hi,
I've been off the hardware world since a while. I currently have a GTX570 SLI. I know from what I read that a single 670 or 680 would beat it.
Also, I saw that the ASUS GTX 680 DirectCU II TOP would have a 20C~30C lower temps at max load and would consume slightly less power (than a single GTX570). Current maximum usage is D3, SWTOR, Crysis 2 (w/ HD and DX11 updates). All at max graph, my room gets hot really quick with two GTX570.
My question, considering my rig (see specs in profile), would it be a smart move to upgrade my GPU? Would I bottleneck somewhere?
Mayoo
Gameplay > Graphics ... oh wait
Food > Gameplay > Graphics > Movies > Sleep > Work
Old July 11, 2012, 11:30 AM
BigPhatPaulie's Avatar
Nope you shouldn't have any issues switching over if you want to do so
FOR PONY..... that is alll
Old July 11, 2012, 12:44 PM
wirerogue's Avatar
if you are upgrading to a single card just because you want more performance, you may want to wait as the gain would be negligible, if any, from your 570s. you may even experience lower performance in some games.
this is only from what i've read as i've been considering the same thing with my 2 6950's. i can't see enough performance gain, if any, to justify the price.
i'm gonna wait for the nvidia 7s or amd 8s.
Old July 11, 2012, 05:05 PM
le2key's Avatar
I agree with wirerogue for the most part. You wouldn't see that huge of a performance gain with the GTX 680 not to mention GTX 670, but if you can get a good price on those GTX 570 I'd say upgrade. I'd upgrade just for the cooler performance and smoother game play (well this is only if you're bothered by micro stutters).
Old July 11, 2012, 09:37 PM
a 570sli is still no slouch by any measure, I went 6950CF because it beats 7950 and I think it mostly beats a 7970 too
i5 2500k - 7950 3GB crossfire - 4GB 1866 CL9 - 1080p
Old July 11, 2012, 10:25 PM
Keep what you have
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old July 12, 2012, 01:40 AM
If you can cover the cost of the 680 DCII Top then sell em.. If you can't then keep what you have.
performance will be very similar.
Old July 12, 2012, 09:55 AM
How about 2 x GTX 670? I can't imagine a performance increase in a single card compared to what you have...
Old July 12, 2012, 10:26 AM
you have too recent technology to consider that an upgrade. Upgrade is when you have cards that are 2-3 years old, not last year's high end. Usually this kind of upgrade is also very costly.
Old July 12, 2012, 10:33 AM
As said, a 680 will be about the same performance, with the benefit of lower power, heat and noise... selling both cards *should* get you just enough for a 680..
If you can cover the cost of a 680 (or at least 480 - 500 $) the do it.. if not, sit happy.
Upgrade/New Wintegrity New Builds 7 May 13, 2011 01:41 PM
Not sure what to upgrade... matari Water Cooling 5 February 10, 2011 06:52 PM
Ram upgrade dante1 RAM 2 February 10, 2011 06:27 PM
VGA upgrade from GTX 260 first, or CPU+mobo upgrade first? panzerfan Video Cards 9 April 6, 2010 08:25 PM
RAM upgrade Hillsdale RAM 6 September 3, 2008 06:31 AM
