<~----> What's the more reliableOC GTX670?? - Hardware Canucks
Old July 11, 2012, 01:23 AM
Default What's the more reliableOC GTX670??
Gigabyte Windforce (cheaper) or ASUS TOP??
Old July 11, 2012, 07:20 AM
great_big_abyss's Avatar
ASUS TOP hands down.
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; ASUS GTX650Ti Boost; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; Sapphire HD5870; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
Old July 11, 2012, 07:26 AM
I have a 50% success rate with ASUS DCT2. My first card would keep crashing/artifacting at stock speeds and even a bit below stock speeds. I had to underclock the boost to about -100mhz to get it to run stable.
I exchanged the card though and my current one runs fine at stock but I haven't pushed it to see if it can go higher yet.
Old July 11, 2012, 07:47 AM
Your first one might have needed the BIOS update, the prob with the earlier batch of Tops is that they were boosting way too high, probably the highest on the market for a GTX 670, so Asus had to slow it down.
Old July 11, 2012, 08:11 AM
I did update the bios. It was probably just a lemon, because my current card has been running perfectly. I've only had it for a day though and have only play a bit of tribes ascend, but the first card would crash the drivers after 2minutes even with the bios update.
Last edited by Sippycup; July 11, 2012 at 10:02 AM. Reason: I accidentally put in too too many words
Old July 11, 2012, 09:11 AM
I still stand by my recommendation that ASUS makes the best, most reliable components out there (ignore the fact the my system specs lists a Powercolour card :P).
Old July 11, 2012, 09:36 AM
Asus has RMA in canada... no brainer for me.
Old July 11, 2012, 09:40 AM
Perineum's Avatar
I totally agree.....
Old July 11, 2012, 09:41 AM
Asus have better customer services and warrenty... so if something were to go wrong your safer with the asus.
Old July 11, 2012, 10:04 AM
I agree. The warranty on the ASUS card is also transferable so if you decide to sell it next year or something the buyer can still RMA.
[FS] Kevin's Cyber Yard Sale - Maximus IV Gene, i7 930, 1366 Waterblock bigFOIG Buy/Sell & Trade 168 June 12, 2013 05:03 PM
