Old July 9, 2012, 10:11 PM
Trial Member
Default 2 x GTX580 and my fps drops to 35-40 ?!
Last weekend i upgraded my rig to accomadate 2 x EVGA GTX 580's, as my last mobo(Asus M4A89TD Pro) would not support SLI, so I bought the Asus Crosshair V Formula. So far, so good.
I also use EVGA Precision X primarily because I'm not 'Bill Gates Jr.' when it comes to overclocking etc. I'm a PC Gamer, if I could get it done with a hamster on a treadmill, i would.
My problem is that I set the Frame Rate Target to 70 fps, click 'Enable', click 'Sync', set fan speed to 'Auto', it's seeing both cards, I have the SLI enabled on the Nvidia Control panel so the Precision X is seeing both cards.
Then.... I load up BF3, set the gfx to 'Ultra' ( the single 580 used to handle this fairly well as long as I set the Antialiasing no higher than x2) and w/ the onscreen monitoring on, I see my fps drop to 35-40 sometimes !
I thought 2 cards should EASILY keep me over 60 fps.
Any help would be very much appreciated.
Old July 10, 2012, 07:15 AM
BigPhatPaulie's Avatar
WHat resolution across how many monitors?
FOR PONY..... that is alll
Old July 10, 2012, 08:02 AM
Hmm. I would turn that Frame Rate target thing off.
What I did with my 2x580's is turned on Adapted VSync via the Nvidia control panel. Anytime FPS is over 60 it turns on sync and caps at 60, anytime it goes lower it would turn off Vsync. I hate the Vsync off tearing so doing this most games would run very smooth.
Old July 10, 2012, 08:07 AM
"Quote This..."
First, get the latest drivers from nvidia.
Second, monitor the gpu usage of both cores during play and see if SLI is actually working.
My 590 gets 60fps in BF2 at 2560*1440 with all the eye candy cranked.
Black belt in CAPS LOCK.
Old July 10, 2012, 03:22 PM
norfolk's Avatar
I have the 580 in my sig and I was running the 296.10 WHQL
Then I upgraded to the latest 301.42 WHQL
I noticed a huge deficit in overall quality in all of my game"s FPS etc,etc.
I ended up going back to the 2 series listed above and all the games are back to the way they were.
I am running all games if possible @ 1080p
Not sure what is going on @ nVIDIA ..... but I think I"ll stick with these for now.
Old July 10, 2012, 03:33 PM
dandelioneater's Avatar
I had heard that some people were having issues with the latest drivers. Oh well, stick with what works. There's beta drivers: 304.79, dunno if you wanna try those.
Drivers | GeForce
Old July 10, 2012, 06:05 PM
supaflyx3's Avatar
He has a 120hz monitor so vsync isn't needed.
Old July 11, 2012, 04:44 PM
norfolk's Avatar
Drivers | GeForce
I didn"t see these drivers I will check out...... Thx dude!
Old July 14, 2012, 07:17 AM
May be your cpu bottleneck your cards
[FS] GTX580 1.5gb importpsycho Buy/Sell & Trade 0 June 3, 2012 04:36 PM
gtx580 3gb model jtf2 Water Cooling 4 July 14, 2011 07:57 PM
GTX580 temps? GT7R Video Cards 7 May 25, 2011 12:50 PM
GTX580 with x4 965be? upcoast604 Video Cards 2 March 3, 2011 02:43 PM
[WTB] WTB: 6950 or gtx580 MarcusFoX Buy/Sell & Trade 1 December 31, 2010 09:52 AM
