<~----> Galaxy GeForceŽ GTX 670 GC 2GB sli vs SAPPHIRE HD7970 3GB DDR5 - Hardware Canucks
Old July 8, 2012, 08:26 PM
Default Galaxy GeForceŽ GTX 670 GC 2GB sli vs SAPPHIRE HD7970 3GB DDR5
What is the best between those cards Galaxy GeForceŽ GTX 670 GC 2GB sli vs SAPPHIRE HD7970 3GB DDR5 in 1080 p resolution
my rig :
i7 3770k
asus sabertooth or asus maximus v gene
8gb g.skill sniper 1866mhz
Old July 8, 2012, 09:26 PM
At 1080p the 670 is better in most games.
Old July 9, 2012, 01:59 AM
sli? at 1080p?
either of these cards will perform brilliantly at that res..
Pick the cheapest or whichever brand (chip or board) you favour.
Old July 9, 2012, 07:25 AM
i want the best frams in battlefield 3 multiplayer 64 player i dont want any dropp in frams DZZOPE i know that one hd 7970 or one gtx 670 will be enough for this game but it wont be enough when you play caspian border 64 players it needs strong video card
Old July 9, 2012, 08:15 AM
great_big_abyss's Avatar
I'm not sure what you're talking about... My stock clocked 7950 pushes approximately 40-50FPS on 64player Caspian Border on Ultra settings at 1920x1200 (as per fraps). A GTX670 or a 7970 will do even better...
You can't really get any stronger than GTX670/680/HD7970/7950 these days...so I'm not sure what exactly you're asking.
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; ASUS GTX650Ti Boost; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; Sapphire HD5870; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
Old July 9, 2012, 08:16 AM
Pabz0r545's Avatar
The 670 is more then enough for BF3 multiplayer. SLi 670's is even better
Old July 9, 2012, 06:27 PM
My opinion... get 1 card... if your not happy just drop in a second... really you would want a large res single monitor or multi-monitors to justify 2 of either of these cards.
Unless you have money to burn a 10 fps drop below 60 isn't worth the extra $430
Old July 9, 2012, 09:28 PM
I heared that ati has bad scaling in crossfirex
Old July 9, 2012, 10:52 PM
Dunno about bad scaling... but reports i've heard (never run x-fire myself) is that the drivers are more flaky and the support for games can be much slower in coming through for AMD..
That said I've not heard much in the last few months about dual card issues (apart from when SKYMTL was doing the 690 review, he had issues with x-fire 7970's.)
Really, you shouldn't need more than 1 card.. even if you dip to 50 fps on 1 map in extreme cases, is it worth the extra spend?
Personally I would go for 1 670, if you want more performance then add a second..
that is of course unless you can get a 7970 for less than the 670..
cost is a big determining factor, otherwise I'd go straight for an Asus DCII TOP 680 or even a 690...
May I ask what your currently using?
Old July 14, 2012, 07:21 AM
I use msi gtx 590 and getting in bf3 single 80 fps ultra 4x msaa but in multiplayer the fps dropps down to 52 fps in some maps like caspian border
Sapphire demos 6gb HD7970 BVickery Reviews & Articles from the Web 12 July 17, 2012 09:44 AM
HD7970 Waterblock scristi Water Cooling 11 February 11, 2012 03:45 PM
Galaxy Develops Dual-Core GeForce GTS 250 Video Card FiXT Press Releases & Tech News 26 March 20, 2010 09:56 AM
Galaxy GeForce Factory Overclocked 8800GT $100 OBO thatguy Buy/Sell & Trade 1 August 27, 2008 06:17 PM
