-   -   help with gpu choice (http://www.hardwarecanucks.com/forum/video-cards/55337-help-gpu-choice.html)
netgears July 8, 2012 08:40 AM
hi i want to buy a gpu dont know wihc one yet so maybe you help me.
evga gtx 680 2gb or
MSI R7970 Lightning Review by VR-Zone.com
dandelioneater July 8, 2012 09:40 AM
I'd go for the 680. Its just a better card IMO
Here's a better review btw: http://www.hardwarecanucks.com/forum...review-22.html
I don't think the ~100 or so extra for the lightning over a reference 7970 is worth it.
edit: Check this 7970 out instead: XFX Radeon HD 7970 Double D 925MHZ 3GB 5.5GHZ DDR5 2XMINI-DP HDMI DVI PCI-E Video Card - XFX - FX797ATDFC
btw I think you have 2 threads going on this atm:biggrin:.
BrutalGreen July 8, 2012 10:31 AM
>1080p go with a 7970/7950
<1080p get a 680/570
netgears July 8, 2012 10:41 AM
what do you mean ?
elmorejohn46 July 8, 2012 11:40 AM
He probbaly means what resolution are you going to be running ,if you are just running at 1920x1080 with every thing on then 2gigs of ram should be plenty but if you are going to run two or three monitors or at a high resolution like 2560 x1600 then the 3gigs of memory will help out alot.
Dzzope July 9, 2012 02:03 AM
if your running at 1080 get a 670... gigabyte or asus are damn good.. :)
PhilT July 12, 2012 10:13 AM
The HWC review of the Asus 670 DirectCU II makes it sound pretty damn appealing if you can find one if you're gaming at 1080p :)
Slik July 12, 2012 11:48 AM
Nvidia all the way. A 680 kicks ass compared to any AMD card. In my humble opinion.
