Old July 5, 2012, 12:30 PM
Default DVI to VGA question
hi there, i have a GTX 670 on my PC and i am using a dvi to vga adapter (connected to AOC e2243Fw via VGA) because i dont have a dvi cable, i wanted to know difference between connecting with the adapter and using a DVI cable.
Thanks
Old July 5, 2012, 01:00 PM
It will limit the res you can run at... but unless your using something high res you should see no / little difference.
Is it that you have no cable or there isn't DVI on the monitor?? would be better to just get a cable if it has DVI
Old July 5, 2012, 01:04 PM
Everything is going to look like crap get a dvi cable asap
Old July 5, 2012, 01:36 PM
Oh well im currently using the VGA on 1920*1080 but i have nothing to compare it so ill just get a dvi, thanks for the help!
Old July 5, 2012, 05:52 PM
Yes vga looks like junk on higher res's
