Old June 28, 2012, 09:16 AM
Arinoth's Avatar
Nope, technically VGA has no limit, its just the fact the higher the resolution you go the shorter a VGA cable you need to use to not have distortion. Aka anything longer then a 6 foot cable at 1080p or higher won't turn out that great.
Here I am: here I remain
Old June 28, 2012, 11:11 AM
Master_Shake_'s Avatar
seeing how there is 2 dvi's in a 6970 did you plug it in to the one that says digital and analog or just digital??
Old June 28, 2012, 05:01 PM
After a long sleepless night, i have finally fixed this. I have now got the option to use 1920x1080 by its native resolution.
Solution, all i did was connect my hdmi cable while i was on vga, that way my hdmi got recognized. Then i switched to my hdmi and made that to be my main monitor instead of the vga. Taadaa.
Thanks for all for helping.
Old June 29, 2012, 04:51 AM
hossdaddy's Avatar
glad you got it resolved!
Main System:
i5 3570k @ 4.6ghz | GA-Z77X-UD3H | Gigabyte GTX 670 | 8gb Redline 1600mhz | CM 690 | Logitech G9x | Mushkin Cronos 120gb ssd | Benq 24" | CM Hyper 212+ | Seasonic 750w | X-Fi Titanium | Sennheiser 350 | Razer blackwidow | Win 7 64-bit
Backup System:
AMD X2 7750 BE @ 3.0G | Asus M3A78-CM | 2x2gig 800mhz 4-4-4-12 | SB LIVE | Samsung 22" | Asus 9800gt | Antec NEO 620w | Logitech G5 | ThermalTake Matrix | Arctic Cooling Freezer 64
Tags
aoc 2436vwh , gigabyte hd6970 2gb , help please , intel dp55wg
Newer XFX HD6970 no backplate? Delavan Video Cards 3 February 22, 2011 06:41 AM
HD6950, possible unlock to HD6970. lowfat Video Cards 72 January 20, 2011 10:13 AM
GTX570 or HD6970 ? Help me decide please. THS Video Cards 9 December 25, 2010 10:36 AM
Gtx 580 sli vs hd6970 crossfire for 2560x1600 prolymphocyte Video Cards 22 December 19, 2010 11:13 AM
AMD HD6970 pictured... Delavan Rumor Mill 57 December 15, 2010 06:28 AM
