Originally Posted by Expect2Die hi all, so i'm planing on buyong a new graphics card and the asus nvidia geforce gtx 560 ti looks the best option for me
but how do i know if it will run correct with my system?
what do i need to look out for cause i don't want a videocard that can't operate in my computer.
so some info on how to see if it will work for me.
Thanks, Expect2Die |
Just look at the specs of your motherboard to make sure it has a PCI-E slot. Its gets a bit more tricky when you start thinking about SLI or Crossfire
