Old April 9, 2008, 06:00 PM
vinister's Avatar
Default HD3870 video inputs on vista not working?
I got a WII, but I have a super-old TV with no video inputs so I can't hook it up. I've tried to plug it into my 3870 using the adapter. However I am running Vista 64bit and I can't find any program that will allow me to access the input.
What am I missing? I expected VLC to do it but the only capture device shown is 'default', and there is no video. I have verified there is a signal present by plugging in a small 7" LCD, it works, but I cant game like that.
thanks for any hints!
Mobo: DFI 790X-M2R
Proc: AMD PHENOM X3 720
Ram: OCZ Platinum 2X 2GB @ 1066
VIDEO: 3 x Visiontek HD3870
Old April 9, 2008, 07:11 PM
sswilson's Avatar
Are your cards VIVO (Video in Video out)?
I'm not sure if I've seen any 3870s on the market yet which are.... I suspect you're trying to input a signal to the component output of the video card.
Old April 9, 2008, 07:33 PM
vinister's Avatar
Hmm maybe you're right. My old x1950 had 2 seperate cables, one with arrows pointing in and one with pointing out, but they both plugged into the same jack on the card. This one came with a cable with arrows going both ways, I was assuming that meant it could be used as an input or an output.
So I guess ati has just scrapped the whole video input feature for their newer cards? That seems a little backwards... it used to work just fine.
Darn I guess theres no other option I just have to buy an LCD tv. =(
Mobo: DFI 790X-M2R
Old April 9, 2008, 07:40 PM
sswilson's Avatar
It's probably the manufacturers who aren't including the VIVO function. If I had to hazard a guess it'd be that they're a bit gun shy of adding any extra costs to current ATI cards for fear of pricing them above Nvidia's offerings.
