Okey, I'm brand spanking new on this forum, but I spent so much time trying to fix this, i'm going to register on every forum where I
looked for a fix and
post the fix I found :
Bios : Turn on integrated graphics card + allow dual monitor on integrated graphics card.
Windows : Go to hardware and turn on integrated graphics card if it isn't turned on.
Software : Install Virtu (
lucidlogix with GPU Solution)
Connect one screen to dedicated GPU and one to onboard graphics.
Problem solved :) Took my HD7850 down from 50°c to 33°c idle at stock speeds. Found out about Virtu while overclocking my HD7850 from
860 Mhz to 1300Mhz core clock 1.3V
