Old August 8, 2012, 10:18 PM
Phill's Avatar
Originally Posted by Galcobar View Post
If it's GPU, it's not surprising -- I ran into a similar issue with my Nvidia card when I went dual-monitor. The GPU would insist on running at full speed with two monitors attached...
Get GPU-Z going, Sensor tab, you should see your clocks.
Goto Control Panel ---- System ----- Advanced System Settings ---- Performance ------ Settings --- Choose adjust for best Appearance ---- then choose Custom(all options will be checked) ------- now Uncheck the first option: Animate controls and elements while in windows ----- watch your gpu-z and see if after 10 seconds it downclocks to 50hz Core, and 68 memory.
Solution discovered by JakeElWood NCIX FORUMS - Attention anyone with nV 5 and 6 series...
Old August 8, 2012, 10:33 PM
Originally Posted by GVCBELGIUM View Post
Okey, I'm brand spanking new on this forum, but I spent so much time trying to fix this, i'm going to register on every forum where I
looked for a fix and post the fix I found :
Bios : Turn on integrated graphics card + allow dual monitor on integrated graphics card.
Windows : Go to hardware and turn on integrated graphics card if it isn't turned on.
Software : Install Virtu (lucidlogix with GPU Solution)
Connect one screen to dedicated GPU and one to onboard graphics.
Problem solved :) Took my HD7850 down from 50°c to 33°c idle at stock speeds. Found out about Virtu while overclocking my HD7850 from
860 Mhz to 1300Mhz core clock 1.3V
That's a hefty overclock considering the concerns over temperatures, I've heard many HD 7850's are capable running the memory at 1300 and the core at 1150. I could be mistaken. HWMonitor is an indispensable utility as well, overclocking or not.
i7 920 - Idle temp 50C Normal? hen555 Troubleshooting 5 April 28, 2012 08:00 PM
Help, High idle temp. Ve11a CPU's and Motherboards 17 March 29, 2012 01:08 PM
Idle Temp Check jcmaz CPU's and Motherboards 3 June 13, 2009 11:19 AM
QX6850 idle temp? pp1111 Troubleshooting 3 April 23, 2009 09:16 AM
just dropped my idle temp by... rob123 Video Cards 11 July 23, 2008 09:03 PM
